-   -   Squirrely Handling After New Tires (http://forums.pelicanparts.com/porsche-911-technical-forum/412326-squirrely-handling-after-new-tires.html)
msk1986911 05-31-2008 03:58 PM
I just had a new set of Yokohama Avid V4S installed on my '86 911. As part of Mr. Tire's package, they provide a free alignment check, which showed that the steering rack was pulling to the right (I should have gotten the numbers but did not). In any event, the front end was aligned (fortunately, the rear was within spec). After much effort on the tech's part, he was able to adjust the tie rods...I should have been more inquisitive as to his experience with 911s):rolleyes: In any event, the tires feel good and whatever shimmy I had at speed with the old tires is gone. The problem I think I have now is that the steering is somewhat vague. It's as if a sudden change in direction induces more roll than movement in the direction that I steer. Could a poorly done alignment cause the problem, or, could worn tires have masked the problem, or, or could something else be going on here?
I lifted the front end and noticed a little play with the left front wheel when I grabbed it at the top and the bottom. he right wheel is solid. Also, when I turned the wheels lock to lock, I could hear a noise coming from the smuggler's box, although it did not appear as though anything was binding.
The car is used just for street driving. I am running 36 psi in the rear and 32 psi in the front. Tire sizes are 205/55-16 & 225/50-16.
Thanks as always.
Mike
john walker's workshop 05-31-2008 04:02 PM
tire shop alignment :( . oh boy! do the tires have stiff sidewalls? push the car sideways repetedly, at the bumpers, and see if the sidewalls move much.
dshepp806 05-31-2008 04:15 PM
Don't forget about the breakin period for the tires.
When I first put rear tires on my car...I was shocked at amount of "squirrel"...thought something was MAJOR wrong. Within several hundred miles, they gripped like all hell. Of course, I didn't dare let this shop touch my alignment, as there were no alignment issues.
Not sure if this is what you're sensing or not. I stick with the door displayed pressures of 36/R and 29/Front.
The play in the wheel sounds like bearing issues (?)
Best,
Best,
msk1986911 05-31-2008 05:08 PM
I'll lower the pressure on the front and see how that feels. I did the push on the bumpers as suggested and do appear to have fairly flexy side walls. :( I have 500 miles to return them; I will see if either I or the tires adjust before then.:confused:
Thanks again for your help.
Mike
jtfreels 05-31-2008 06:55 PM
I have the V4S tires on my SC, I've not experienced any odd behavior, for normally driving I run at the recommended pressure, for autocross I've gone up to 34F and 37R and they still drive great.
Jay
911nut 05-31-2008 07:02 PM
Get the alignment checked or check it yourself.
Nitrometano 05-31-2008 07:07 PM
Can be a bad ball joint. Also check if the wheel is tightened.
msk1986911 05-31-2008 07:54 PM
A couple of the nuts on the left front were definitely not as tight as as they should have been (I didn't have the torque wrench on it, although the amount of effort required was no where close to 90-95 foot pounds:mad:). All nuts have been re-torqued. Tomorrow's test drive should tell the story.
Thanks again.
Mike
javadog 06-01-2008 02:21 AM
For what it's worth, the pulling issue is more likely a result of uneven caster than incorrect toe. Hopefully he checked that as well. Adjusting the tie rods has nothing to do with that. There should also be no play at all, as you describe. Was there any play after you torqued the wheel nuts? An incorrect toe setting can make the car feel like it isn't very eager to turn into a corner. Porsche specifies the toe setting "pressed" which means they want you to set it after you install a device between the front tires that pushes on them with a cretain amount of force. Did he do this?
JR
Can you post the numbers that you ended up with after the alignment?
Pkaaso 06-01-2008 06:20 AM
You might want to try a different set of tires. I had the same problem with my 74'. I got new tires. It went from nice accurate steering to what seemed like a flat rear tire. Felt like the rear end wanted to come around with the slightest turn. Too soft side walls sounds like your problem.
If tires is the only change you've made from OK to NOT OK, I'd change to a different tire. Tell your tire guy, "these don't work."
My $0.02
Paul
scottb 06-01-2008 07:16 AM
Did you do what this guy did? http://tinyurl.com/5uh2nn
He put Armor All on his tires to make them "jet fockin' black." Unfortunately, he Armor Alled the tread, to. Talk about squirrelly! (The Armor All guy is one of my all-time favorite threads). Sorry to hijack!
DARISC 06-01-2008 07:25 AM
The YOKOs in particular seem to have a lot of mould release still on them when new. It wears off after a few hundred miles of so. I wouldn't mess with tire pressures or alignment until you're sure that's not the problem.
That's been my experience with the last 2 sets of YOKOs that I've put on my car (my mech. warned me about this when I put the first set on).
Wickd89 06-01-2008 07:32 AM
Are those all weathers? If so switch to summer tires (if it is not a daily driver).
I tried some Bridgestone 960 AS Pole Positions and they were TERRIBLE..
I swapped them to Goodyear F1 DS-GS summer tires and they are really great.
I went from slipping all over the place to an awesome handling Pcar with great grip.
The alignment needs to be done by someone that understands 911s. Local shops usually have no clue and cannot dial you in.
msk1986911 06-01-2008 08:33 AM
I stopped back at the shop this morning and was given the readings before the alignment was done last week which were: Camber: -0.2 degrees (left) and -0.6 (right); toe: 3.93 degrees (left) and -3.63 degrees (right). They did not have the readings from when after the alignment was done, in which case, they put the car back on the rack and took readings which were way out of spec (I was told the car was in spec last week after the alignment). In any event, the readings after today's alignment are now: camber: -0.6 (left and right); caster adjust: 6.0 degrees (left) and 5.0 degrees (right) and toe: 0.13 degrees (left and right).
BIG lesson learned here: find a shop with a tech that worked on a 911-the tech while he was careful and courteous (despite his reference to my car as a museum piece):eek: had some real problems trying to adjust the tie rods, so much so that I was asked to leave the service bay since I might be making him nervous. :rolleyes: The upside is that I have a few hundred miles within which to decide to either keep or pitch the tires. Also, I can go to any Mr. Tire to have the work done. The Porsche mechanic I go to for mechanical work recommended a Mr. Tire closer to him...I should have taken it there although I thought it was too inconvenient, that was BEFORE I spent 2 hours at Mr. Tire last week and another 2 hours today!!!:(
Wickd89 06-01-2008 09:16 AM
I drive 60 miles from home to Gardena, CA to get a good alignment.
DARISC 06-01-2008 09:25 AM
When buying my last set of tires, I had my thinking about old 911 alignment realigned :).
Noticing the wear pattern on my YOKO AVS ES100 tires (worn into the wear bars, slightly more toward the inboard sides, at about 18k miles), and before buying new tires, I took it to my mech.'s alignment guy who's very experienced aligning 911s (for street and track).
He asked me if I was unhappy with the mileage I'd gotten out of the tires, which I wasn't. Then he asked me if I was unhappy with the handling, which I wasn't.
Then he asked me what I wanted him to do. I said,"Huh?". Do you want a more agressive camber for looks or for the track?, he asked. Uh, no, I answered, to which he replied that I didn't really need him to do anything.
He said he's had a number of 911 owners want increased camber for the look, didn't track their cars and then were shocked at their tire wear, so for years he's "interviewed" his customers as he did me.
I thanked him (there was no charge) and drove off with a smile on my face and my money still in my wallet. Honesty rules! :D
Jim Richards 06-01-2008 10:19 AM
They had before readings but no after readings? If so, that seems odd unless they never did/finished the alignment and rolled your car out to get the next one in. This is a good lesson for sure. It makes sense to avoid the tire shops where there's a premium on business volume and the skill/quality of the tech might not be all you'd hope for.
RoninLB 06-01-2008 10:29 AM
http://members.rennlist.com/imcarthur/alignment.htm
WolfeMacleod 06-01-2008 12:46 PM
I have the Godyears and can't stand them, really. To me, they seem very squirrely or "sqoogey" as I call it. Sidewalls seem too soft, and I get nothing but tire squeal at Autocross.
msk1986911 06-01-2008 01:04 PM
If I were a betting man, I'd put money on that. Not to say there aren't tire shops that have qualified techs, just not one at the shop I chose. I should have dug deeper into the tech's experience and qualifications.
Jim Richards 06-01-2008 01:10 PM
We all have our stories to tell. That's why Pelican Parts and the PPBBS are such huge resources for the Porsche community.
rfn026 06-01-2008 01:28 PM
If he was adjusting the tie rods then he was adjusting the toe setting. It's just about the easiest thing you can adjust on the front of the 911. It's so easy that people refer to it as toe-n-go alignment. One way to make money is to charge for a four-wheel alignment and give the customer a toe-n-go.
I seriously doubt if the tech was nervous adjusting the tire rods. They just wanted you the hell of the shop.
If the alignment was free then you got exactly what you paid for. Find a real alignment shop and have the car corner balanced.
You might also spend some time learning what the various settings do. For instance I like a little toe-out at the track because I get quicker turn in. I also max out the caster - being careful to make both sides absolutely even. Most alignment shops set the caster different on the left and right sides to compensate for the crown in the road. It works but I've never been a big fan of it.
Richard Newton
Wheel and Tire Performance Handbook
ramonesfreak 06-01-2008 01:51 PM
i notice anything more than 30psi in the fronts and i get a very vague feeling, at times scary feeling of no control--especially as the gas tank gets emptier. try 30 and below, and, a few hundred miles of break in and this should go away
Wickd89 06-01-2008 02:03 PM
+1
I like 29 on my fronts...
msk1986911 06-15-2008 05:12 PM
After having the tires for about 2 weeks, I think I am getting used to the feel, although I think I prefer the more direct response before the new tire install. In any event, I took a closer look at the tie rods and noticed that both are squeezed where the tech used vice grips to hold it them while loosening the lock nuts. Should I be concerned that the rods are not 100% cylindrical? As posted previously, BIG TIME lesson learned here. At the very least, I should have taken the car to the tire shop recommended by the Porsche mechanic (same big chain company, different location).
dentist90 06-15-2008 08:56 PM
I had your experience, but with Yoko ES100's. Went in with older Yoko's (520's, I believe... NLA) on the rear, came out with the ES100's. No alignment issues, already had ES100's on front from PO, no other changes. My car became quite tail-waggy all of a sudden. At home in the garage I pushed the car side-side and the only movement was in the sidewall. The sidewalls of some tires are definitely not as stiff as others. Have played with tire pressures to try to stiffen sidewall: end result was that the rears wore out in about 15,000km at the center rib (running at 36psi).
RoninLB 06-16-2008 07:05 AM
OT about tires
S-03 Bridgestone replacement.. notes in tirerack
I wore through 2 full sets of S-03's and loved them.
they are NLA
The Bridgestone replacement is 050A PolePosition and has about 1,000 miles on them.
The sidewall is stiffer than the S-03's. It's so stiff I thought it has to be my imagination. When I shake a front or rear fender side to side I would see some slop on the S-03's. On these new replacements it's like I'm trying to shake a brick wall. They ride like I jacked up the psi on the S-03's at least 10psi each.
I kept psi on both same at 29/35
I haven't read from other pelicanheads about this S-03 replacement issue either.
A couple of guys said "maybe they have to soften?" which doesn't make sense to me..
so this is just a heads up
ps: "2 full sets" means 4 tires on 1 set.
ie: 40,000 miles on 8 tires
John-1977911s 06-16-2008 07:30 AM
If the tires are directional they may be on backwards.
I had a shop do this to me once and the car was very much all over the road. I took the car back to the shop, they reversed tires and the car drove like new.
dshepp806 06-16-2008 01:11 PM
I'd get that baby to a pro and have 'em make it perfect (I think someone sugg'd this earlier). Not comfortable with non-P wrenchs touching mine...(and to call it a "museum piece",...WTF? )
Tires (as mentioned) will take a bit of miles to break in....
msk1986911 06-16-2008 03:17 PM
Tomorrow I am taking the car to the big chain franchise first recommended by the Porsche mechanic. They will validate the alignment and comment on the tie rods. Hopefully, I won't kick myself in the a$$ for not going to this location in the first place (at least for the tire install).:o..don't get me started about the scratch on the lip of one of the wheels...no curb-rash Fuchs:mad:. I am sure the scratch can be blended out. At this point, it is the principle of the matter.:confused:
RoninLB 06-16-2008 03:44 PM
Originally Posted by msk1986911 (Post 4006565)
Hopefully, I won't kick myself in the a$$ for not going to this location in the first place (at least for the tire install).:o..don't get me started about the scratch on the lip of one of the wheels...no curb-rash Fuchs:mad:. I am sure the scratch can be blended out. :
my bro in la la land had scratches on stock Fuchs from the tire installer.
he had them buy him a new wheel. This happened 2x at different places.
burgermeister 06-16-2008 05:02 PM
I missed the discount tire install ... check your oil lines and rocker covers for crushing if you bring the car to a non-porsche shop (which I'd avoid at all costs).
msk1986911 06-26-2008 06:34 PM
I took Mr. Tire up on their 500 mile or 30 day trial :Dand returned the V4S tires and got Yokohama S Drives instead. Dollar wise it was an even swap (shipping consumed the difference in the price). In any event, after one drive, I can feel a difference: much more direct steering response, although it could be my imagination. All in all, I feel good about the switch.:cool:
