Unknown part HELP
Hi
Do you guys know what part is this? It's the black part ( rubber? ) between the oil filter and gas filler neck. It's connected to rubber lines. I'd like to replace it because it has cracks. Part number? Thanks Miguel http://forums.pelicanparts.com/uploa...1212737446.jpg |
See this recent thread: http://forums.pelicanparts.com/porsche-911-technical-forum/412247-need-source-part.html
Also if you put gas in that "gas filler neck" you are going to discover some bigger problems. :p |
Unknow part
Hi
Thank you for your quick reply. Did you finally find that part 930 207 243 01 (check valve sleeve)? BTW. I've been putting gas in the engine bay filler neck without any problem. For oil filling, I prefer to use the the front left fender hole. :confused:;) Thanks again Miguel |
| All times are GMT -8. The time now is 04:31 PM. |
