-   -   Two questions - switch & part # (http://forums.pelicanparts.com/porsche-911-technical-forum/413727-two-questions-switch-part.html)
Jim F. 06-09-2008 05:37 AM
First - while replacing the hi/low beam switch I dropped a little screw into the opening on top of the wiper switch. It's one of those real small screws - didn't feel like pulling it all apart to fish out. I tried the wiper and it worked fine. Put it all back - happy that I was able to accomplish the replacement of other switch - but, after getting on the road I found that the wipers didn't work!
Do you think the screw may have shorted out the entire wiper switch - or possibly cooked the fuse? I'm going to go back over everything now.
Also - the metal plate - square - that slips over the sterring shaft - acts almost like a dust shield - the horn plate goes over that then the wheel back on. It would be the 3rd part to come off when removing the wheel. does anyone know the correct part # or name of the plate (held with 4 tiny screws at the corners). Or does anyone have an extra?
It went back together ok without it, but it bugs me!
Thx.
Jim F. 06-09-2008 06:55 AM
answer to above
it was a simple blown fuse! so, instead of $120 for a new switch i put out $1.99 for a bunch of extra fuses - not bad.
still hunting that plate answer though.
tcar 06-09-2008 07:50 AM
Screw could have (probably) shorted it. If fuse pops again, you'll need to get it out.
Rod w/ magnet might do it.
