Follow me
seymore's Avatar
oil cooler scoop
How many people have one of these and do they work well? I'm speaking of the little scoop on the corner to cool the oil cooler. My oil temp was higher than I like today and I was thinking of getting one. Thanks
Old 06-12-2008, 03:20 PM
On the corner of what?
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 06-12-2008, 03:36 PM
Follow me
seymore's Avatar
Passenger side turn signal
Old 06-12-2008, 03:37 PM
Turbo 13b guy
JayG's Avatar
I have one that I made and it makes a difference in my water temperatures for my intercooler. (have an aftercooler mounted where stock oil cooler goes)
That being said if it made a difference for that Im sure the oil would run cooler.
1975 911S Targa(333 hp/276 tq)
Old 06-12-2008, 03:41 PM
Trotskyite
Not really. You will need to pair it with a few other upgrades to have any effect at all. Do you have a carrera style cooler already?
Grip Fast
Old 06-12-2008, 04:07 PM
seymore,
I bought one maybe eight years ago, and it's seen many modifications to get it to work better.
To answer your question, no it does not work "well", but I need to explain.
My '84 had the finned cooler, without a fan. I added the scoop, and found that it does not really flow any air. The scoop is a scoop in outside appearance only because the air sort of dies once it is "scooped". I added some internal baffles with a smooth sweep that forced air directly onto the cooler. It worked somewhat better, but the cooler itself is not boxed, so air hits the finned side and then flows around the cooler. The real improvement came when I added the factory fan. Now, when I run the AC I never really see oil temps above 210, whereas before I frequently saw oil temps climb over 240, which I feel is way too hot.
I think another problem is that hot air is thin air, and when temps climb to 105F with the low humidity we have here, it takes much more air to carry away the heat. The scoop is not effective alone.
I also pull up on the heater levers, run the rear blower air through the heat exchangers too. I end up cooking the center cv boots faster, and the front right tire gets a little bit cooked too, but that's ok.
Old 06-12-2008, 04:22 PM
Follow me
seymore's Avatar
I have an stock 82 SC. what other upgrades are there for around the same amount of money?
Old 06-12-2008, 06:21 PM
I have sold almost 2000 of these scoops and not one returned because "It didn't work", actually not one returned at all. I have had one on my 78 including the wood one that was a prototype for about 7 years now and wouldn't be without one. Buy one and if doesn't do anything send it back. I accept returns from all my distributers.
Jerry
JM PRODUCT DESIGN
Old 06-12-2008, 06:28 PM
Jerry,
I really feel that you should add an internal baffle to make the scoop flow air to the cooler. To be honest, the air needs to be ducted directly from the scoop to the front surface of the cooler. As it is, you are sort of hoping that the air decides to flow through the cooler. I think the winning setup is to make the scoop feed air to the fan, and then the fan does the heavy work of forcing air through the cooler.
If you want, I can take some macro shots of what I did to mine.
Seymore, did you check this article out?
http://www.pelicanparts.com/techarticles/911_extra_cooling/911_extra_cooling.htm
Old 06-12-2008, 06:58 PM
Follow me
seymore's Avatar
Jm pro do you work for PP or another site?
Old 06-12-2008, 06:59 PM
greghershner's Avatar
Send a message via AIM to greghershner
Jerry,
Do you have the Pelican Item number? Thanks
Greg Hershner
1985 911 Carrera Coupe
Warrensville, NC
Carrera 3.2 - "Faster, Stronger, Better"
Old 06-12-2008, 07:06 PM
Designer King
Paulporsche's Avatar
I have had one for several years, as you can see. What you may not be able to see is that I also hollowed out the fog lamp below and fitted a piece of plastic behind it to direct air up to the 28 row cooler. Between the scoop, the modded fog lamp, a slightly rich mix, and disconnecting my vacuum retard, I can keep my temps manageable. How much each contributes, though, I really can't tell you.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 06-12-2008, 07:16 PM
MBruns for President
JeremyD's Avatar
I've had one on my 1987 for a few years since I did my 3.4 - even running at sebring at 95 degrees I have not had cooling issues. I works to funnel cool air - especially with a carrera cooler
Old 06-12-2008, 07:38 PM
Porsche-pa
75Carrera's Avatar
What kind of screen covers do you have on that Paul? I really like that. I'm about to replace my front valance and thought about deleting the fog lamps (I never use) but wondered what it might look like with nothing there. This is a great look. And the air to my 28 bar cooler would be welcome for sure...
Current Garage:'04 996TT S Cabriolet, 1975 911 Carrera 3.2 powered (my Precious),
Also rans...
'02 996TT, '03 996TT, 1967 912, 95 993 C2 Cabriolet, 76 911S Carrera, 2014 Carrera S, 2014 Turbo S, 1999 AMG SL, 1966 Lotus 7,
Donny
Old 06-12-2008, 07:50 PM
tdatk's Avatar
If your running at the track, another way to get the air to the oil cooler is to pull your headlight and swiss cheese the bucket. It's right in front of the oil cooler and with the headlight out, the bucket works like a scoop to funnel air to the oil cooler.
Tim
82 SC
90 C2
Yasowatt
Old 06-12-2008, 10:15 PM
Mark Mcgarry's Avatar
Try a old shop vac.
81 930 euro sunroof delete
Garrett custom turbo, Tec 3 EFI, 964cams, GT3 oil pump
Andial intercooler, Tial wastegate
RarlyL8 headers and muffler
Lindseys 9s 11s
Old 06-13-2008, 05:58 AM
Designer King
Donny,
After I removed the workings of the lamp, I drilled out the back of the housing. I then took some of the expanded metal aluminum screening that is placed over eavestroughs to prevent leaves from gathering and siliconed it into place. This material came in both black and clear anodized. I used the ca to more closely replicate the lense of the other foglamp, which I left intact. The plastic piece behind to try to direct the air is held in place by the same bolt that secures the lamp.
Paul
Old 06-13-2008, 06:10 AM
Porsche-pa
75Carrera's Avatar
Very nice Paul. I didn't notice the left light was still intact. Excellent idea. Especially with that lamp upgraded to a driving light for those dark, lonely night roads...
Do I understand you siliconed the screen to the inside of the original fog lamp rim that would normally hold the lens on? What year fog lamps did you use. Are those the originals that came with your '77?
Your quote: "Never leave well enough alone" or "Good enough" just isn't! Thanks, pal!
Also rans...
Donny
Old 06-13-2008, 06:27 AM
IMHO if you really want to solve the oil high temp issue you need to install a front valance oil cooler.
Few of us have tried all those gizmos/gaggets with marginal results... Save some time and money (engine wear) and go with the cooler - it is not that expensive anyway, looks good and WILL work.
Old 06-13-2008, 07:04 AM
That's a stock Carrera (84-89) front valence and fogs.
Old 06-13-2008, 07:19 AM
