intermitent failure 1983 930 euro
i've been having an intermitent problem with car shutting down suddenly as outlined on my other post. i narrowed the promblem down to moving wiring harness in engine compartment towards firewall. when i do this i can get the car to shut down. the rear fuel pump makes a different sound and may be shutting down as well. what could cause this to happen? is there connection up there for the wiring harnees or just connections a t the fuel pump. any info would be greatly appreciated.
Old 06-14-2008, 08:22 PM
the rear pump connections are in the engine compartment between the CD unit and the shock crossmember.
206 637 4071
Old 06-14-2008, 10:59 PM
that's exactly where the is. what's the best way to access those connections?
Old 06-15-2008, 06:33 AM
E-85 sippin drunk
turbobrat930's Avatar
You might have gotten a better response by posting this in the 930 forum....BUT... You can gain better access to that area if you take off the I/C ( intercooler). I have a feeling though that you have not done much maintainance on your 930. If that assumption is correct, do not do anything to your car... take it to a shop and let them do it. There are seals on your I/C and TB ( throttle body) that are very easy to pinch, and if you do, your car will run like crap...and you will have no idea why....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 06-15-2008, 08:20 AM
turbobrat, you're right, i just got the car and i'm just finding my way around it. i'm probaly going to have a mechanic look at it but would have liked to find the root of my problem so i could eliminate the chance of breaking down on the way to the shop. thanks again for the heads up.
Old 06-15-2008, 11:37 AM
