Need Float Setting - Zenith 40TIN Carbs
Hello - Yes, I've done a search here, no cigar. I need the spec's for setting the float level on my 2.2 carbs. They are the Zenith 40-TIN model. Thanks much......
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Tree-Hugging Member
Try this:
~~~~~ Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners. ~~~~~ Last edited by Jim727; 06-11-2008 at 11:54 AM.. |
Thanks Jim -I can work with this. I already have them apart and on the bench. I was hoping someone had a measurement from the bottom of the float to the gasket surface of the carb. Thanks again...
Tree-Hugging Member
Bob -
Glad to help. I'm thinking that when I have a bit more time I should scan that complete doc into a .pdf for Wayne. As I recall, the float-to-gasket-surface dimension is not adjustable; the float pivots fit into their mounts and are screwed down. All adjustment of float/fuel level is done with the brass washers under the needle/seat. At least that's what my memory says....
~~~~~ Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners. ~~~~~ |
Jim is correct, you adjust using the tool and adding or deleting shims.
Robert Williams 70' 911T |
Got it all figured out. I work on motorcycles so much, I was thinking I could bend one of those "Tang" thangs to adjust. I now see that's not the case. Almost the the 1st set cleaned and ready to go back on.
Be sure and measure the float weight. They absorb gas and sink.
Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
I now find a ham-fisted previous owner over-tightened one of the long Idle-jets and broke it. Any ideas on where to shop for parts for these carbs? (I think it's the idle jet, it's the one about 1.5 inches long just below the float drain plugs?)
