MBruns for President
JeremyD's Avatar
How long to install Turbo Tie Rods?
On a 1987 Carrera? Wayne's book says 4 hours -
I'm going to change out my brake pads so will have the car jacked up anyway (and the wheels off) - also I consider myself to have a little above average mechnical skill - and a refrig full of beer in the garage - so what say you?
So, Turbo Tie Rods love you long time?
Old 11-04-2004, 07:32 AM
ha. I have the same beer fridge, 87 911, & turbo rods still in the box. I was wondering the same ?
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 11-04-2004, 07:35 AM
about an hour if you have the tools and know how to separate the tie rod ends from the steering arms. (BFH).
206 637 4071
Old 11-04-2004, 07:55 AM
JeremyD's Avatar
Which you just use the tie rod seperating fork, right?
Old 11-04-2004, 08:11 AM
I was quoted an hour and a half by my mechanic, but I'd assume they are versed in this stuff.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 11-04-2004, 08:31 AM
targa911man's Avatar
The trick is loosening the large brass circular nuts that the boots are attached to. It also acts as a locknut. There is a hub wrench (half-circle with a tooth) readily available at most bike shops which fits the notches on the brass thing, making the jobl a lot easier. You don't reuse them, so you can take channel locks or vise grips to them as well. I can attest that if you leave this step out (as Wayne's instructions do--sorry Wayne) it will in fact take you from 4 hours to never. Two hours if you loosen the brass nuts. Caveat--sometimes those brass things are real tight and it can take a considerable amount of time-consuming bad language to get them loose. Once you get them loose, you can then resume following Wayne's instructions and "simply unscrew" the tie rods from the rack.
Dan Morissette
'85 Guards Red Targa 911
My Owners Gallery Page
Non illegitimi carborundum
Old 11-04-2004, 08:50 AM
mikester's Avatar
Send a message via AIM to mikester
It took me and a buddy about 2 hours to do them on his 914...I still need to do them on my 911.
-The Mikester
I heart Boobies
Old 11-04-2004, 08:54 AM
Bandwidth AbUser
Jim Richards's Avatar
The BFH (per John Walker) combined with the bicycle hub wrench (per Dan - aka targa911man) makes this a reasonable project. After Dan and I learned on his car, I did this on mine and it took me a couple of hours by myself and in no particular hurry. I have a beer fridge too.
Jim R.
Old 11-04-2004, 08:55 AM
One other thing--it may look like you don't need the spacers that come with the kit--put them on.
Dan Morissette
Old 11-04-2004, 09:03 AM
JeremyD's Avatar
BFH = ?
big friggin hammer. it's the original tie rod end popper, way back to the first tapered tie rod ends. if you give the outer end of the steering arm a hard, sharp wack, or several, the tapered tie rod pin will pop out. i've never used a pickle fork in my life.
the inner lock ring can be loosened with a BFH and a long chisel or punch. set the chisel in one of the notches and rotate it in the loosening direction a bit. no need for special tools here.
206 637 4071
Old 11-04-2004, 09:12 AM
Bandwidth AbUser
Actually, I remembered incorrectly. I did it like JWW said, using a BFH and a cold chisel on my car.
Jim R.
Old 11-04-2004, 09:15 AM
JeremyD's Avatar
I love you man!
Old 11-04-2004, 09:44 AM
djmcmath's Avatar
If you're mechanically inept, this project may take you an awful lot of beer. I consumed a significant amount of time (and beer) lying under my car trying to remove the tie rods. Like other suggest, a big pipe wrench on the brass lock nut really helps. Once you loosen that sucker, it's all over.
The other thing that'll get you is the boot -- be careful not to tear the boot when installing it. And be careful not to destroy the silly little boot-springs -- those buggers shred apart with a lot less force than you might think.
(shrug) I figure, having done it once, I could do it again in about 2 hours. Someone with skill who had read this thread a few times to get the gotchas could probably do it in about the same, or a bit better. Good luck.
Dan
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 11-04-2004, 10:17 AM
silicone spray on the new boots. the new boots don't use the old springs.
206 637 4071
Old 11-04-2004, 12:11 PM
djmcmath's Avatar
No kidding? Bummer -- I put a lot of work into getting the old springs onto the new boots, too. Thanks for the info.
Dan
Old 11-04-2004, 12:16 PM
Jeff Alton's Avatar
I just use a proper tie rod end removal tool that you tighten down on the rod until it pops. Real easy and no banging.
Jeff
www.turn3autosport.com
Old 11-04-2004, 01:04 PM
If my car is factory turbo look, does she came with turbo tie rod ?
Tan
911 1987 Triple Black Cab Turbo Look >> weekend car
SPF MK III Shelby Cobra 427 550HP >> thrill for speed
BMW 88 635CSi daily drive
BMW 87 325i use for rainning day (donation)
Benz 06 E350 use for pick-up kid on car pool day
Old 11-04-2004, 01:53 PM
Jeff Alton's Avatar
The short answer (I think) is no. But it may have been upgraded. My understanding is that was the one thing that was not "turbo spec".
Jeff
Old 11-04-2004, 09:07 PM
anthony's Avatar
Jack it up and take a look.
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 11-04-2004, 09:09 PM
