Installing CBP on '86 3.2, Need New Nuts & Bolts
After a couple of hours of battling with the stock hardware, I was finally able to remove the cat from my '86 3.2.
Obviously, I cannot reuse the stock nuts and bolts. Any suggestions or recommendations on where I can find the correct hardware, and/or what size(s) I should be looking for? Thanks! Chris |
Fastenal, Lowe's, Home Depot, Tractor Supply, Ace Hardware, or any other place that has metric bolts and nutz.... They are nothing fancy, all you need to do is bring your old bolts and such down there, and they will fix you up....
Thanks.
Got them and all wrapped up with the job. Chris |
| All times are GMT -8. The time now is 01:04 AM. |
