porsher
aston@ultrasw.c's Avatar
oil lines leaking at crimps
The oil lines from the thermostat to the oil tank and crossover pipe are weeping at the crimps on the flexible hose.
I was thinking of taking the lines to a local hydraulic hose shop and having new flexible sections crimped on.
Is this a good idea, or should I just buy new lines. What should I look out for.
TIA
Old 06-14-2008, 05:28 PM
Porsche 911 SC, SAAB SPG
You can definitely get new hose with new crimps installed by a hydralic shop.
I just did this with my car. I did have some problems finding a shop to do it though. Just be sure to tell them that you can reuse the current fittings. I didn't know this at first and a couple of shops turned me down because they didn't have the right fittings on hand.
Jeff C
Old 06-14-2008, 05:35 PM
burgermeister's Avatar
You can also cut the crimps off and clamp on 7/8ID oil line from aircraftspruce.com, or -16AN braided line (more widely available), with a few common hose clamps. Works just fine on my car - these are low pressure lines. Got the idea from jonbot and Tim Hancock.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 06-14-2008, 09:43 PM
Born to Lose, Live to Win
ramonesfreak's Avatar
im having the same problem. have not fixed it yet though
oil hose leak?
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 06-15-2008, 04:01 AM
Interesting - I hadn't seen Chuck's replies. Inspections I can't comment on.
But, I wonder, from an engineering perspective, what a crimp does that a clamp does not? Certainly, crimps would be faster, cheaper, and more consistent for automated mass production. Also, crimps provide a means of holding the hose on the outside as well as the inside - clamps would only serve to hold the inside of the hose to its nipple. This would seem to matter most on high pressure hoses. Am I missing something else?
That said, I have had a crimped oil line blow apart on my driver ... not fun at all, though it reinforces the fact that you can indeed drive an engine without oil for a few minutes without doing damage (other than a horrendous mess).
Old 06-15-2008, 08:29 AM
A fellow Pelacanite
NathanUK's Avatar
I've had hoses rebuilt using the same ends and new crimps.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 06-15-2008, 02:16 PM
Autobahn Garage
I have the tools in my shop to crimp the oil lines and A/C line. I repair them on a regular basis. I takes hand tools to remove them, I you can't find somone to repair them in your area send them to me and I'll redo the hoses and the crimp fittings for you
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 06-15-2008, 08:36 PM
