What are these? (Pics of parts)
I just put a new battery in the 79 911 SC I just bought and seen these, not sure what they are or what they are for. They are all located in the fron dirver side by the battery. First pic looks like an old bypassed fuel pump?? It has a bolt in one end capping it off and the other end runs into the fender out of sight. Second part was beside it with one wire connected and the other broke. Third are what appear to be some type of vaccume lines many of which are broken or disconnected. My guess is some one bypassed this stuff at some point. Could someone tell me what this stuff is and what it is for? Thanks
2004 SRT-10 Viper powered ram
2006 Hummer
1989 Mustang supercharged 5.8 351 TKO600 5 speed
1987 Buick Grand National
1979 Porsche 911 SC work in progress
Old 06-28-2008, 07:34 PM
Band.
1. ? (i'm guessing "headlight washer pump.")
2. Windshield washer fluid pump.
3. windshield washer lines.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 06-28-2008, 07:39 PM
Diss Member
Quicksilver's Avatar
Not sure why they marked #1 as a 'blank' but that is all parts of the window washing system.
If you look it up in the Pelican parts system there are some pictures that will clear it up. It should be easy to trace it up to the nozzles and back to the tank.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 06-28-2008, 07:44 PM
Thanks for the help. Now I will start to get it sorted out.
2006 Hummer
Old 06-28-2008, 07:55 PM
I believe that the blocked line was the factory line for the headlight washers. If you're car has that deleted (like mine) then the line is still there but capped. It would have gone to the second hi-power pump for that system.
Or, it's possible that someone replaced the bumper at some point, and didn't include the washer system, and capped it. Mine has a nice metal plug, not a bolt.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 06-28-2008, 08:41 PM
