-   -   SC help please - what is this thing? (http://forums.pelicanparts.com/porsche-911-technical-forum/415089-sc-help-please-what-thing.html)
haycait911 06-16-2008 09:03 PM
located on the roof between the visors. what is it and what does it do? it's in an '80 ROW SC. any help much appreciated. I'm still very much an SC newbie. Don.
http://forums.pelicanparts.com/uploa...1213675294.jpg
http://forums.pelicanparts.com/uploa...1213675328.jpg
Johnb911 06-16-2008 09:08 PM
I am pretty sure it the interior heat sensor (Thermostat)
Bill Douglas 06-16-2008 09:09 PM
It's wired into the thing between the seats that doesn't do anything either.
haycait911 06-16-2008 09:15 PM
great! another climate-control thing. you know, I counted the other day. there are NINE different climate control levers and knobs. I like german engineering, but seriously, NINE!!??
dentist90 06-16-2008 09:18 PM
...and don't lose that because they are NLA. I had to track down a used one for 75% of the new list price. I THINK it works, because when I first turn the heat on in the morning I get warmth, then after several minutes I can hear the servomotors on the heat exchangers whirring and the heat delivery tapers off.
haycait911 06-16-2008 09:23 PM
those servomotors, are they what makes that lever between the seats move as if posessed? I had to keep a copy of the heater control diagram from the owners manual in the glovebox of my '73. with this car I may just drive it in summer. I think I have the A/C figured out. :D
dentist90 06-16-2008 09:44 PM
Yea, I imagine it would. I have the auto heating system, no levers... just a knob. But the only way to control heat getting into the cabin is to open and close those rotary valves at the heat exchangers. That's what those levers between the seats do. I didn't realize that auto heat control came with the lever type. Wacky!
http://forums.pelicanparts.com/uploa...1213677809.jpg
javadog 06-17-2008 04:50 AM
The cars with auto heat also came with a lever that was to be used if the auto heat controller failed. To use it, you had to remove a screw in the side that connected it to the servo linkage.
These systems really aren't all that complicated, guys. Most of the questions I see on this board could be answered by reading the car's owners manual.
JR
at7driver 06-17-2008 07:50 AM
My 1980 euro SC has the compass installed there... I will get a pic up later but that is where its at.. just went out to verify.. yes that is where the compass mounts.. our camera is full of andretti karting pics from last night so its going to be awhile till i can get a pic loaded.
javadog 06-17-2008 07:51 AM
Compass? That sounds like an owner-added aftermarket thing.
JR
at7driver 06-17-2008 08:04 AM
here is the pic of the compass
hope this helps..
http://forums.pelicanparts.com/uploa...1213715056.jpg
at7driver 06-17-2008 08:07 AM
hey Java,
remember these are euro cars, their roads dont go east/west like here in the states.. haha...
seriously though I dont know if its an owner add on deal or not.. I just got this car last month and havent researched that kind of stuff.. it is coming off and in a box anyway, she is going on a diet starting in july..
It would be interesting to find out if this thing was from Porsche or an add on.. if nothing else just to have that additional piece of info on the cars.
thanks,
david
DARISC 06-17-2008 08:16 AM
Part of antenna assembly on RoW coupes (I think). I removed mine and the part in question when I had the car painted. You can see it hanging down in the middle picture. My car never had automatic heating to the best of my knowledge.
http://forums.pelicanparts.com/uploa...1213715185.jpg
http://forums.pelicanparts.com/uploa...1213715565.jpg
http://forums.pelicanparts.com/uploa...1213715781.jpg
javadog 06-17-2008 08:18 AM
That's an add-on. Somebody shoved it up into an interior temp sensor for a car with automatic heating. Hope they didn't screw up the sensor, those are hard to find.
JR
javadog 06-17-2008 08:20 AM
Originally Posted by DARISC (Post 4007662)
Part of antenna assembly on RoW coupes. I removed mine and the part in question when I had the car painted. You can see it hanging down in the middle picture.
[/img]
I hate to tell you this but that wasn't a factory antenna and the sensor hanging down had nothing to do with the antenna...
JR
DARISC 06-17-2008 08:23 AM
JR
Didn't know that. The car came from Germany with the antenna shown.
javadog 06-17-2008 08:31 AM
Factory antennas were in the fenders. If you had a manual antenna, Porsche put it in the left fender. If it was a power antenna, it went in the right fender. The ones in the roof were typically cell phone antennas added by a shop. I never figured out why they typically drilled a hole in the roof to install those. Over here, we used the kind that glued to the glass and "transmitted" through the glass to a base glued on the inside.
I, too, have removed one of those infernal things from a car and welded the hole shut.
JR
at7driver 06-17-2008 02:38 PM
my antenna is in the left front wing.
I will pull out that compass pronto. I am taking out the auto heat later this year anyway, BUT any way to determine if the sensor is functional ???
thanks,
david
javadog 06-17-2008 02:40 PM
thanks,
david
Yes, you can measure its resistance. I don't have the correct value off of the top of my head, and my manuals are in a warehouse 10 miles away, but you should be able to search this board and find it. It's been discussed before.
JR
equality72521 06-17-2008 02:46 PM
So THAT'S what the hole in my headliner is for!!! I've been wondering for a long time.
dentist90 06-17-2008 07:27 PM
thanks,
david
One would think that resistance should vary with temp, but testing isn't that easy as the connector for it is a tiny plug kinda shaped like a DC adapter plug.
Bill Douglas 06-18-2008 12:03 AM
This is what I did with the servo motor in my SC.
The levers work really well.
http://forums.pelicanparts.com/uploa...1213772573.jpg
Quicksilver 06-18-2008 04:14 AM
When I first got my car years ago, I stopped by the local Porsche dealer to order the owners manual. While I was there I asked the guy if he could give me a run down on all the climate controls while I waited for the manual to arrive. He said, "Sure" and came out, looked it over for a bit and then shrugged and said, "I have no idea." :D
dentist90 06-18-2008 07:03 PM
It's really simple. If you're too hot, open the windows. If you're too cold... close them! ;)
