German odometer replacement sticker?
I am working on the restoration of a 1977 Carrera 3.0 that was originally delivered to an owner in Germany. While removing the carpet in the area of the drivers side kick panel, I found the sticker shown in the picture below. I'm hoping someone in Germany has seen one of these before and can confirm to me what I think it probably is.
It measures approximately 36mm by 46mm and is made from the same material they use for small tickets (like they use in raffles.) There is a company name in the middle, "Berner," and a word across the bottom that might be:
Kompres_onsdrucks__eiber.
I can't make out the three missing spaces shown above. Below that appers to be the word Motometer. Written by hand along the right side is 20038 km. There are a few other letters and numbers that make no sense.
I figure this is either a sticker showing that the odometer was replaced at a certain mileage or a sticker showing a service was performed at a certain mileage. Anybody seen one of these, or speaks enough German to translate the word above?
Thanks,
JR
Old 06-18-2008, 09:53 AM
I have seen those before. It's an engine dyno compression printout.
Mike
'68 911 # 11830241
Old 06-18-2008, 12:01 PM
304065's Avatar
This is for the moto meter version, yours happens to be a Berner "Kompressionsdruckschreiber" But it's the same thing
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-18-2008, 12:18 PM
An engine dyno compression printout?
Please, tell me more.
JR
Old 06-18-2008, 02:00 PM
304065's Avatar
No dyno.
German compression testers use a little pen to scribe the readout on a piece of paper for each cylinder. Wayne doesn't sell these, but www.samstagsales.com handles the Moto Meter line. You use it the same way as you use a regular compression tester but it records the readings. And it's about 20X more expensive.
'81 R65
Old 06-18-2008, 02:05 PM
John,
Thanks for the explanation. Now the few numbers that I can see on the sticker make some sense. A record of a compression test beats the heck out of an odometer replacement sticker.
I figured this question would twist in the wind for quite a while. It amazes me how much collective wisdom resides on this board.
Many thanks,
JR
Old 06-18-2008, 03:48 PM
