-   -   Windshield washer system: which hose goes where? (http://forums.pelicanparts.com/porsche-911-technical-forum/415657-windshield-washer-system-hose-goes-where.html)
bob tilton 06-19-2008 09:50 PM
My car never had the parts so I need help figuring how to plumb the system. I'm hoping someone would take 5 minutes to look at their system and tell me what hose goes where, "B goes into 2". Thanks in advance.
PS I know I have extra hoses just because I figured it to be easier to cut the ones that were more difficult to insert in awkward positions. I'm gonna keep the lines coming from the pump.
PSS This is the last on my to do list before I can strip the tank and finish my front compartment project. http://forums.pelicanparts.com/uploa...1213941042.jpg
rusnak 06-19-2008 10:15 PM
I can't quite make out the year from the washer bottle tank. Maybe we can dig up some pics and parts diagrams though.
bob tilton 06-20-2008 06:29 AM
It's a 68 which is the year they retained the pump pan mounted bracket but switched to the newer bottle. In 69+ the pump mounted to the bottle. A diagram or pic would help. TX!
ossiblue 06-20-2008 07:13 AM
I just did this last night, but my memory is still not exact. First, pop out the black plug where your #1&2 are located, and find which fitting is attached to the tube that reaches to the bottom of the tank. That fitting should attatch to nipple ZZ.
Tube C should connect to nipple YY.
Connector D should plug into the black stopper as the return line nipple.
Tube B should plug into connector D.
I am assuming tube A leads to the nozzles.
Plug in the ground connector (brown) only in it's proper terminal.
Connect a jumpwire to the + terminal, and test your setup by touching the wire to the battery. Water should flow through the system. If not, switch the tube connections to YY and ZZ and retest. If it still doesn't flow (but the motor is running) try switching the terminal connections.
steve911 06-20-2008 07:57 AM
Bob--
There's a concurrent thread here if it helps any:
http://forums.pelicanparts.com/porsche-911-technical-forum/415580-windshield-washer-hose-diagram.html
bob tilton 06-20-2008 08:36 AM
You guys are awesome - TX!
rusnak 06-20-2008 09:48 AM
I'm giving this thread another bump because the PET only goes back to 1970. I have to remember to call Porsche and pick up my parts diagram CD ROM. Maybe it goes back farther.
rusnak 06-20-2008 09:58 AM
http://forums.pelicanparts.com/uploa...1213984673.jpg
dunno if this helps
bob tilton 06-20-2008 10:31 AM
More than I could ask for! TX!
bob tilton 06-20-2008 07:39 PM
Thanks again guys. Got it hooked up tonight. Man it's hot in the garage!
