M491Cabriolet's Avatar
How to test a 1972 911 Tachometer ?
I have a spare (1972 manufacture) 7300 RPM 911S tachometer for my 1972 911T. The tachometer looks perfect, but I don't know if it works. Is there any way to test these things without actually installing them? If so, how do I do it? I'd just like to see if the needle (arm?) sweeps.
If it ends up being dead (no movement of the needle/arm), what could be possible causes and who would be able to repair it (and how do would they do it)? I don't want to start off thinking it won't work, but you never know, and just in case, if it doesn't, I want to know what to do to fix it.
FYI, I'm redoing my 2.4 liter engine to either S or E spec (or some combination thereof), which is why I want to eventually install this particular tach--apart from the coolness factor. For my engine rebuild, I have all the parts (Mahle 2.4 S and 2.2 E pistons and cylinders, and original S and E cams with MFI drive, and a 1972 911S 7300 RPM distributor). I wish I could decide which combination of P/Cs and cams I should use for the most fun on a street car so I could sell the extra stuff to someone who needs it.
Thanks in advance for any info and advice.
Old 06-22-2008, 06:03 PM
Zeke's Avatar
For testing and repair, you can send it to North Hollywood Speedometer. If you have an early car with the purple/black wire coming off the distributor, you can hook it up at the dash. If your car doesn't run right now, you could put in on friend's car.
I don't know how to bench test it on a DIY basis.
Old 06-22-2008, 06:12 PM
Anyone know how to do a DIY benchtest?
Thanks. I'd rather just try to benchtest it on my own before dropping even more cash toward a pro's bottom line. Of course, if this tach does not work, a pro is going to get it. Does anyone know how to test one of these things? What it the voltage that comes from the purple wire? I imagine it increases with revolutions, or pulses somehow. Any ideas? Thanks.
Old 06-23-2008, 03:59 AM
304065's Avatar
11 volt square wave to the /1 input-- search here
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-23-2008, 08:22 AM
Tach troubleshooting... at a roadblock and need suggestions
Old LorenFB suggests dragging the tach input over a file that has been grounded.
Rick
88 Cab
Old 06-23-2008, 09:07 AM
