hose length
Does anyone remember how many feet of hose they ordered to install a front-center bumper mounted oil cooler with inlet and outlet on right side?Thanks,T.C.
Old 06-25-2008, 12:18 PM
porsher
aston@ultrasw.c's Avatar
Obviously, it depends on the routing.
I used about 17' to replace the hard lines for a stock (85 Carrera) cooler in the front PS fender well.
This is pretty much useless data for you....However, here's an idea. I found that the hose (12AN) would not route out of the thermostat and along the rocker without kinking. So I purchased 90deg hose ends and it they worked great.
Old 06-26-2008, 12:37 PM
Using the factory '74-on hard lines, about 5' of -12AN hose, (2) straight, (2) 45º swivel fittings and (2) AN-to-metric adapters.
I suggest using the factory or equiv. hard lines up to the front. They're not that difficult to find and routing and connection to the system will be easier.
Sherwood
Old 06-26-2008, 02:28 PM
