-   -   Speedometer making clicking/grinding noise (http://forums.pelicanparts.com/porsche-911-technical-forum/41618-speedometer-making-clicking-grinding-noise.html)
pcasd 06-18-2001 11:22 AM
Anyone know what might be causing this? Speedo bounces especially when slowing down through about 30 to 0. Clicks correspond to bounces. Is this something I might be able to fix or do I have to send it off somewhere for big bucks. Thanks
Dan S.
1974 911 Targa
pbs911 06-18-2001 11:39 AM
I had this problem with others cars, not the P-car. Turned out to be the speedo cable and not the guage. Check the connections at both ends. It may have come loose.
Paul
78SC Targa
Planter91C2 06-18-2001 12:22 PM
<font face="Verdana, Arial" size="2">Originally posted by pbs911:
I had this problem with others cars, not the P-car. Turned out to be the speedo cable and not the guage. Check the connections at both ends. It may have come loose. </font>
same here too, but the speedo cable just needed to be lubricated. do this at the connection.
pcasd 06-18-2001 12:42 PM
Thanks guys,
Can I assume I get at it through the trunk and not through the dash?
Dan S.
1974 911 Targa
Jens Wendorff 06-19-2001 01:23 AM
Pull the speedo out of the dash and you will be able to grab the nut of the drive. Should work "hand tight" w/o tools.
Getting there through the trunk requires removal of the fresh air unit as far as I remember.
Jens
'76 2.7 CIS with '73 body conversion
pcasd 06-19-2001 11:02 AM
Thanks Jens,
I guess at this point I should point out that the only manuals I have are Clymer and Haynes http://www.pelicanparts.com/ultimate/frown.gif Would the Bentley manual or upfixnderporsche cover procedures like this. I hate to just start tearing stuff apart due to my propensity for totally Effing up most everything I touch on this car.
Dan S.
1974 911 Targa
