83 CHECKER
anyone ever install 83 cabriolet top???
Hi, I Have Completed The New Top On My 1983 911sc Cabriolet, After Countless Hours It Is Complete, But Thr Rear Window Is Not Taught. It Has Wrinkles In It, Not Tight, Others I See Are Nice And Tight No Wrinkles, I Noticed Two Adjustment Threaded Shafts Or Screws In The Upper Rear Sections Of The Frame, Theyseem To Be Adjusted Way Out, Should I Tighten Inward Or Futher Out To Hopefully Tightn Up The Rear Winow Section, Make It Nice An Unwavey Or Wrinkled, The Rest Came Out Great, Or Perhaps Something Else I Should Be Doing? Please Any Help Would Be Great. Should Have Left This One To The Pro's I Think. Thanks Bob
Old 06-24-2008, 05:30 PM
Happiest when Tinkering
gsmith660's Avatar
The factory says to put it out in the hot sun or heat it up with a blow dryer to get the wrinkles out. You might post a pic to let us know how wrinkled it is. Cheers and good luck.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 06-24-2008, 07:28 PM
when you install the reat top wet it and pull it tight .glue it. when done with the top put in the sun .presto the top will be tight
Old 06-24-2008, 08:27 PM
3.2 CAB's Avatar
I did my 84. It is a real PITA, isn't it? When installing the new rear section, those adjusting rods that are on both sides need to be loose and adjusted so the rear section, when installed can be adjusted "outward" after the new section has been installed to remove the wrinkles and to "tighten up" the rear top section. The entire top has several adjusting points, even the hinge arms are adjustable, to result in an almost wrinkle free "new top" Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 06-25-2008, 07:23 AM
