Brake Booster and CIS
Where does the brake booster hose go on a CIS system.
On the Drivers side of the Air box? What else attaches there, a check valve or something? Thanks.
Jeremy C. Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham) ----Nothing is far away in this car!--- -2001 996 Turbo |
Somatic Negative Optimist
By all means, do not tell us what year/type you have.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
78 SC, thought that was visible in my signiture
![]() Thanks Gunter
Anyone have a pics or two of their 78 CIS where the booster hose goes. Thanks
On a '78-'79 CIS, the vac hose for the Brake Servo is connected to a nipple coming out of the airbox on the driver's side.
Should be a short steel nipple threaded into the airbox. The hose clamps on to the nipple, very simple. If the old hose is too short, or brittle, use a new one.
Nipple
Gunter, thanks for the info. Would you happen to know wht athe part nuber is?
I have read a lot of discussion about the booster needing vacuum above and below the TB in order to work properly. Is this the case for the 78? If so, how would the one connection with the nipple accomplish this? Thanks Again for your help!!!
Part number for the steel nipple would be available on Pelican Parts list or call them.
With '80-'83 years, the vac was indeed taken from both top and bottom of the throttle plate simultaneously ending up in a Y-connection single hose to the Servo. I have experience with both versions and cannot tell the difference; works fine either way IMHO.
So, i found three possible parts in the catalog. What is the difference between 930-110-357-00, 911-125-341-01, and maybe 90511672500?
930-110-357-00, 911-125-341-01 look the same; one is a lot cheaper than the other.
It's a mystery; I don't know. Maybe order the one for $8.- and try? Do you see the threaded opening on the left side of your airbox?
Routing of brake booster vac line........
OK, this is what I found out. 911-125-341-01 is for pre 80, but is list for cars with Sportomatic and I would need 911-125-341-02 (not sure why they would be different) the other 930-110-357-00 is for '80-83 cars.
Of course the one I would need is the most expensive, so I called the local P-car dealership and they said both of those parts have to be ordered from Germany, however the one i need is not available. So my thought would be to try the other. Thanks for your help...
Brake booster vac line routing.......
![]() Long vacuum hose going through the engine bay inner section: ![]() Vac hose connected to the steel tube going thru the tunnel: ![]() The other end of the steel tube (vac line) comes out in the front hood near the brake booster. HTH. Tony |
Tony thanks for the pics!!! Just what I needed. Now to find the right part...
The brass, U-shaped and oddly plumbed part allows for vacuum to be drawn by both the airbox and the upper throttle body (above the throttle body plate). Does the upper throttle body connection allow for more/better vacuum at idle or is the reverse true? Brian
'82 SC Targa '83 SC Cabriolet |
