brake pad warning light
The warning light on my '87 Carrera stays on all the time. It was that way when I bought it two months ago. The po said he could't figure it out. I have new pads and sensors. Actually I have one new sensor in front and one in back. The other two are disconnected. What else could cause the light to stay on other than the dreaded short in the wiring somewhere?
1987 Indian Red Carrera Targa
Old 06-27-2008, 02:14 PM
aj88cab's Avatar
This might help:
Brake wear idiot light on; sensors removed
Good luck
Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 06-27-2008, 02:22 PM
The light is out- finally. Thanks to help from this forum I finally understood how the system works. The Bentley manual was no help. The light is a much a check of the system as it is a brake wear warning. If anythng is not right the light comes on.
Old 06-28-2008, 11:55 AM
dshepp806's Avatar
Not quite sure about "anything", as you put it! but, the circuit does drive a few signals into the box.
What was the problem with the Bentley Manual (as related to your troubleshooting),...and, especially,....
.........what did you find causing the light to be ON ?????
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 06-28-2008, 05:22 PM
