Virginia Rocks!
VaSteve's Avatar
Thermostat O-ring ... which one
It looks like there's two of these...red and green. Which did you use and what's the difference. I did this job once, it's leaking again.
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_ENGoil_pg3.htm
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 06-26-2008, 05:06 PM
DUK DUK is offline
DUK's Avatar
Different manufacturers. I've got a green one and (knock on wood) no leak.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 06-26-2008, 05:20 PM
Immature Member
dentist90's Avatar
The one I just took out was black (and brittle). Put in a red one. It better work!! I'll let you know in a few days.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 06-26-2008, 09:31 PM
mine was green. but I don't think the o-ring should fail. Did you notice any damage to the o-ring when you got the thermostat out?
Old 06-26-2008, 09:53 PM
Immature Member
dentist90's Avatar
That's true, the o-ring should last for 10+ years. It can be hard to determine where the leak is coming from up there. I couldn't tell for sure if it was the breather hose/gasket, the oil pressure switch or the thermostat o-ring. Took the shotgun approach and covered them all. The condition of my thermostat o-ring and the volume of oil coming out makes me think that was the problem in my case.
Old 06-26-2008, 09:58 PM
statistically, almost not possible it's the case. The o-ring lasts me about hmm...5 years due to the weather we get here. The reason is that it takes a lot of heat and 60 psi of abuse.
When the oil pres switch fails, you have a geyser of oil shooting out of the top of the motor, and scary amounts of oil on the exhaust pipe. The only other thing it might be would be one of the crankcase breather hoses.
Old 06-26-2008, 10:04 PM
red o-rings are soft, green is quite a bit firmer. green lasts longer.
206 637 4071
Old 06-26-2008, 10:11 PM
Here's a picture that shows the engine (not mine) from the front, and why you know you have a leaking pres. switch or o-ring if you have oil dripping onto the exhaust cross pipe and oil on the top of the motor.
Applies to 3.2 and 911SC
Old 06-26-2008, 10:18 PM
Immature Member
dentist90's Avatar
Oh cr@p! Not what I wanted to hear. I've had the motor out 3x in 2yrs. The only good thing is I'm getting quicker and I get to recheck the torque of my CV joints annually!
Old 06-26-2008, 10:26 PM
Red is Silicone rubber & green is Viton.
Viton ones are superior due to its abilty to resist attack from petroleum products and heat.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-26-2008, 10:37 PM
dtw dtw is offline
GAFB
I like the Viton ones, they seem to drop into the thermostat bore with a lot less fuss.
Had a 'rebuilt' 2.7 I installed last year (not my build) and among the numerous issues was a lake of oil at the back of the motor. Pulled the t-stat to find the original black o-ring, which was hard as a rock and fell off the thermostat in 3-4 crunchy pieces.
Several BMWs
Old 06-27-2008, 06:17 AM
