Early 911 axle removal
I want to replace the CV boots on my 68'. What do I need to take off to get the axle out? Does the stub just pull out of the transmission? Any tips?
You don't really want to remove the stub from the transmission. Just remove the bolts holding the CV's to the stubs. You may find it easier to remove the castle nut on the outside stub, and remove that end from the trailing arm, then split the CV from the outer stub axle.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
