DME test, repair/exhange?
Any recommendations on sources who test, repair or exchange DMEs? Any sources in Maryland with spare DME that I could try in my son's 911 to determine if his is faulty? Thanks...
Mike Pate baby sitting '88 911 Commemorative Edition (60k miles) for son in Baghdad |
Somewhere in the Midwest
For local help...potential DME loaner, go join the Dorkis in your area..
http://www.dorkiphus.net/index.php Search DME repair. Someone posted a company that specializes in fast DME repair...I don't have the link handy right now. They do all Bosch ECU repairs. |
I responded to your post over on Rennlist...
Make Bruins Great Again
Find another car with the same DME and do a swap. That's the easiest way to test it. Repairs are available through our host (although being on the west coast is a hassle if you are on the east side like me).
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
I can't find the info at the moment, but I remember Loren posting that certain conditions can damage a loaner DME too. Might want to be careful about that.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
What Wavey said (and that was part of my post on Rennlist). There have been several who have warned about that, so swap the "potentially bad" DME into the good car and see if the problem follows the DME instead.
Hi Believe Steve Wong from 911chips does repairs too.
86 Garnet Red Cabriolet |
they are going for about 30 bucks on this sites new parts section.
'14 Cayenne GTS '04 996 Coupe '02 C4S Coupe '99 M Coupe '84 M491 Coupe |
ps: If Mike is referring to the DME relay, that's easy: Pelican order
That is why you put the suspect DME in the car that runs and see if it works there.
Rick 88 Cab |
Right. The previous posts didn't make that clear, therefore my post.
You could have a sensor issue (load) that could be shorting the DME drivers,..you wouldn't want that to happen on your friend's DME!!!!!!!!! Just like the guys said: put your DME into another car and see what shakes..NOT the other way 'round.
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
