Porsche VIN - unique? 1972 T,E,S?
Looking at purchasing a project 1972 Targa "barn" find... vin is 91125111xx
5th digit means T,E,or S
1 is at 911T
2 is a 911E
3 is a 911S
Whats a 5 mean? Is it Euro spec? desireable?
Car had a 911S owners manual, engine was fuel injected with a green shroud. Had full gauges. What is this car?
thanks!
Old 07-01-2008, 02:52 AM
slodave's Avatar
51 is for a 911 T Targa. RoW
Old 07-01-2008, 02:57 AM
It came orginally with carbs (vergaser).
http://www.elferhelfer.com/fzident/fzident72-73.htm
A green shroud and fuel injection would suggest an E-motor but the engine case nr. should give a definite answer on that.
Martijn
'66 3.2 "Blue Car"
'73 3.0 "Orange Car"
'78 3.2 "Brown Car"
Old 07-01-2008, 05:12 AM
Do you have the engine number?
Old 07-01-2008, 09:08 AM
Alright... let see... here the scoop on the car...
1972 911 T Targa not currently running.. sitting for 3 years
vin# on the registration is 91121xxxx and 91125xxxxx once the owner can find a way to pop the hood we can match the vin and the current registration... either way its a 911T targa.
engine number is 6450xxx I guess that means its a 1975 911S engine... it has a green shroud.
car looks otherwise solid except for rust on the door bottoms (easier to get 2 donor doors) rockers at the jacking point is rusted thru, hood front has bubbling, rust thru at the tow loop at the front trunk area. otherwise car looks straight.... hasnt been run in three years... has Fuch wheels 15" and good targa top, also turbo whale tail. cars has steel SC flares are the rear...
what is this car worth?
Old 07-03-2008, 01:01 PM
I'd say the car is worth $3,000-$5,000. But rust at the jack points is a VERY BAD SIGN. And the '75 S engine isn't a plus either. If you love it, go for it. But check the windshield -- are the words "money pit" visible?
Sandy
1969 911E
1970 240Z
Old 07-03-2008, 01:26 PM
