gliderguy's Avatar
Stuck in Georgia need help Pelicans
Hello all,
Well it has been awhile since my last post.....I guess that happens when your girl is running good. Recently had the motor redone at Steinels Autowerks....she has ran like a champ, however my shift linkage seems to be out of adjustment. I am not able to "find" 3rd and fifth gear. Are there any pelicans that can refer me to a shop????? I am in Acworth Georgia 20 minutes north of Marietta.. Any suggestions will be helpful..... I will post picks of car when I get home. The motor is beautiful you could eat of the top or the bottom... So I need to find somewhere that can make adjustment. I am afraid to tinker with it myself. Hope to hear back soon. sitting in hotel trying to figure out next move.....
76 911/2.7/SSI/2in 1out/tensioners/Ice Green Targa
01 Suburban
02 Jeep Liberty
WillsWings Eagle
"As I hug the mountain tops in my hang glider, the only distraction Is looking below at the roads I will hug with my 911 "
Old 07-01-2008, 06:54 AM
Somewhere in the Midwest
MotoSook's Avatar
This is an easy fix. You just need an allen wrench (5mm IIRC)and a Phillips screw driver.
Remove the tunnel cover at the rear using the Phillips screw driver.
Loosen the shift coupler. Before you do that: Because you're already having problems getting into 3 and 5, put the car in any gear you can, then loosen the coupler. Put the shifter in the gear that the tranny is in, then tighten the coupler.
Try to row into the other gears. If that works, you now justs need to fine tune the adjustment so that all gears engage well w/o grinding.
I like to begin the adjustment with the shifter when in 3rd or 4th as it better centers the shifter and shift fork. So once you are able to get into 3rd and 5th, try this. It is usally one shot deal for me when I start in 3rd and 5th.
Good luck.
Old 07-01-2008, 07:18 AM
gliderguy's Avatar
Just looking for a name of a shop I could "limp" her too.
01 Suburban
02 Jeep Liberty
WillsWings Eagle
Old 07-01-2008, 07:23 AM
mcvgums's Avatar
try Ryland's in Marietta
770-951-9305
1983 SC - IROC interpretation White
1999 996 Silver/Boxter Red
Old 07-01-2008, 07:25 AM
Somatic Negative Optimist
Gunter's Avatar
Souk:
Allan key? You are thinking of something different.
He needs a box-end wrench to adjust the coupler.
http://www.pelicanparts.com/techarticles/911_shifting_improvements/911_shifting_improvements.htm
gliderguy:
You can do this.
Follow the factory shifter adjustment procedure. It is as follows:
a) Take off the cover between the rear seats, which exposes the shift coupler. Pull up the shifter boot, particularly so you can see the lower part of the shifter lever where it bends from "angled back" to more vertical.
b) Loosen the retaining bolt, which pinches the shift rod on to the spline on the shift coupler. Let it be very loose.
c) WITH THE TRANSMISSION IN NEUTRAL, rotate the shift coupler clockwise when viewed towards the front of the car. You should be able to feel the coupler rub against the various shift stops as you rotate it back and forth. Rotate it to the furthest clockwise position, as seen when you are facing forward. Don’t pretend you are Tarzan and turn it with huge force....lightly is all that is necessary..
d) Keep your hand on it and hold it there. Don’t let it wiggle, if it does, turn it back to the furthest clockwise position.
e) Move the shift lever so that the more vertical part of the lever is vertical (ie 90 degrees to the level...sticking straight up so to speak). Move it so that it lightly touches the side of the shifter housing which is on the 1st/2nd gear side.....closest to the driver. Again, gently.
f) They should now be properly aligned.....lever closest to the driver with bottom part vertical, coupler clockwise in the neutral plane.
g) Carefully tighten the pinch bolt. Make sure it is quite tight.
h) Check things out. You must be able to engage reverse clash free (give the gear a little bit of time to stop after you stomp on the clutch), shifting should get to all the gears easily when driving.....things don’t work as smoothly when stopped and lastly, there must be a little bit of rotational play when 5th gear is selected. This is checked by shifting into 5th, and feeling whether you can wiggle the shift coupler with your hand. It should just click back and forth slightly...not much, but clearly discernable play.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 07-01-2008, 07:42 AM
Shop in Norcross
Jack Lewis Enterprises is a great shop in Norcross, 60 RAKESTRAW ST
NORCROSS, GA, 770-849-0302.
I've known Jack for many years, and he works on street cars, vintage racers and modern racing 911s. You're likely to see early 356s, 911s, 914s, maybe a racing 996 all in the shop.
DrChet
Old 07-01-2008, 08:06 AM
dshepp806's Avatar
Well, it's about 8 PM and this Georgian is checking in on you,..as I'm located dead center..
You make OK?
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 07-01-2008, 04:57 PM
gliderguy's Avatar
THANKS to all that replied......With time not being on my side, I looked on the local PCA website and started calling numbers....After speaking with, two extremely helpful gentlemen, a garage was found. Conclusion....Needed new shift coupler assembly, plastic bushings were shot...... Cary at Premier Service Center in Alpharetta went above and beyond expectations in all areas of the interaction. Very fair price....quick install, extremely personable...and knows Porsche's inside out. I have continued on to my first destination before I hit home. Wife and I are near Lookout mountain outside of Chattanooga now and will end up back in ohio by late wednesday night. Car is running wonderfully and I am battling between listening to my radio or the mini symphony I receive via my exhaust. Again thanks for all replies and thank you to Cary at Premier!!!
01 Suburban
02 Jeep Liberty
WillsWings Eagle
Old 07-01-2008, 09:42 PM
Driving member
jester911's Avatar
Steve, I am glad you ended up with Kerry. Anytime I need work done that I can't do I take it to Premier.
Great to hear he got you taken care of.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 07-02-2008, 03:47 AM
dshepp806's Avatar
Yes, good newss,..I had my trailer prepared for you,
Best,
doyle
Middle Georgia
Old 07-02-2008, 04:05 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Just saw this, I am only 5 miles away and would have gladly looked at it for you. That being said, Kerry is a 100% stand up guy.
Old 07-03-2008, 07:54 AM
gliderguy's Avatar
Thanks again to all.... I will make it a point to take some photos. Steinels Autowerks in Ohio did a amazing job on my motor. I am back home now....going to take the girl for a little afternoon run......HAPPY fourth of July!!!!!!!!!
01 Suburban
02 Jeep Liberty
WillsWings Eagle
Old 07-04-2008, 11:12 AM
