Changed to synthetic oil, now i have leaks?
I have 75 911s 2.7
I bought it used a few month ago, i changed the oil to mobil 1 synthetic cuz its been a garage queen and he couldnt even remember when he changed it last. Well i had it for a month before i did this and not a DROP of oil. Now i change the oil and i got a pretty good oil leak. A friend said synthetic oil tend to creep through old gaskets??? Should i just change back to non-sythetic and it wont leak?? Confused.. |
Yes, Mobil 1 synthetic will leak more. Switch to a good quality 20w50 dino oil. It will stop leaking.
James 1969 911E Slate Grey 1981 911SC Wine Red 1997 911C4S Ocean Blue |
AutoBahned
search on brad penn
dino = non-synthetic oil
I use Swepco 306 15w-40. Do a search, you'll find more than you need.
1989 Carrera Hookem Horns! |
RETIRED
Air cooled motors hate synthetic oil....lose it.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Replacing the leaky parts will do the trick.
1987 Carrera 3.2 |
RETIRED
Sure, why not keep the 3x the price oil and replace a bunch of parts that don't need it....works for me.....
I never heard of "dino" until this board. Then I started using it. I don't even know for sure if it is pronounced like "dino-saur", but I assumed that is where the term came from.
+1 on the Brad Penn. It is $5.83 a quart here in Seattle. I used Kendall recently because it was on sale and found metallic dust in my oil plug at the next change. No such dust with the Brad Penn. True pennsylvania crude oil with better ZDDP in it (zinc, phosphorus).
I run synthetic and have no problems with it whatsoever. No leaks and as far as I can tell my car doesn't seem to 'hate it'.
