fitchn's Avatar
oil temperature sender?
In my 911 SC the oil temperature gauge seems to have packed up and gone on vacation. Upon startup the gauge does move off of "zero" up to 60 on the gauge but then never moves, regardless of driving conditions, ie even in 95 degree weather. This makes me suspect the sender from the motor is no longer working but I haven't hooked up a voltmeter and looked at the signal or anything of that sort. Trouble is, I can't seem to find the oil temperature sender in pelican's catalog, only the backdating piece that is no longer available (one of Wayne's 101 projects). Anyone know the correct part number? Excuse my ignorance if this has been covered before as I couldn't find it with a search. Thanks, Noah.
Noah
79 SC
minerva blue metallic
Eureka CA / Boulder CO
Physics is like sex, yes there are some practical applications, but that's not why we do it.
Old 07-05-2008, 06:14 PM
Send a message via AIM to fintstone
If you have the backdated gauge with numbers on it, you need this sender:
901-641-632-00-M100
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-06-2008, 10:08 PM
