Shaun @ Tru6's Avatar
Early Mystery Flywheels
I have 2 flywheels here and need help identifying them.
One is 5-bolt, other is 6-bolt.
5 has no identifying number on it and is heavy.
6 has 910.102.205 0 R and is quite light (comparatively)
They are the same diameter, off by about 2mm on height.
Tru6 Restoration & Design
Old 07-05-2008, 06:30 PM
304065's Avatar
Count the teeth. Five bolt = NARP
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-06-2008, 05:27 AM
Both have 130 teeth, the 6 bolt has a new ring welded on
NARP = 914?
Do you know where I can get specs for the 910 wheel?
Old 07-06-2008, 06:24 AM
djpateman's Avatar
Yes, the 5 bolt looks like a stock 914/4.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 07-06-2008, 06:49 AM
BURN-BROS's Avatar
Any timing marks on the 910?
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 07-06-2008, 07:18 AM
none that I can see. it does have a large 574 scrawled into the outside wall, but that's it.
Old 07-06-2008, 09:57 AM
djpateman's Avatar
On the 5 bolt, others on the Early S list mention VW, however with the bearing residing in the flywheel it is definitely 914.
Addicted since 1975
Old 07-06-2008, 07:49 PM
sww914's Avatar
Looks like a 914-4 and a 914-6 to me.
Old 07-06-2008, 08:21 PM
Fuchs w h o r e
I believe the late Bus 228mm flywheel has the bearing in the flywheel too, just like your VW-Porsche 914.
Old 07-08-2008, 01:24 AM
thanks for the ID's on these. if anyone knows where I can find the specs for 901 flywheel, please let me know. want to know if it's in spec, and how far.
Old 07-08-2008, 08:56 AM
sww914's Avatar
Nearly every automotive machine shop should have the flywheel specs. They should know how thin it can be cut and still be safe.
Old 07-08-2008, 11:04 AM
