-   -   Too A/c Or Not Too A/c? (http://forums.pelicanparts.com/porsche-911-technical-forum/419064-too-c-not-too-c.html)
robert walsh 07-10-2008 02:55 AM
Hi, i have an 83 cab with a/c that i don't use, i think it needs a charge nonetheless, since i am not using it would i hurt or damge anything, such as the compressor, by removing the belt, in theory i should get a little more power, i don't want to remove it physically from the car, it just wouldn't be justified to me as a weight reduction over eliminating the stock appearence and possible future use. thanks bob
slodave 07-10-2008 02:59 AM
No problem. A lot of people do that. I did, then I removed the rest of the A/C.
WPOZZZ 07-10-2008 02:59 AM
I pulled the belt on my 85 cab. No problems whatsoever.
tcar 07-10-2008 07:36 AM
No problem, but you're not going to see the increase in power that you suggest... none at all, since the compressor isn't engaged.
