83 CHECKER
strut brace yay or nay?
Hi, have ordered several parts of late waiting for arrival to install, keep you posted on the results, any thoughts on how effective a strut brace on a 83, cabriolet, not racing or anything, just to improve body flex and general handling?? not sure if they are worth the investment, or for that matter what exactly they are suppose to do or improve. thanks
MBruns for President
yes - although I went with the rennline with the integrated monoballs. Definite improvement in steering response
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
I also am a big fan of the Rennline
-Andy '67 912, '92 C2, and '93 RSA - all gone
THE IRONMAN
Sure...I can feel a small improvment in general handling (cornering). But mine is not three point one.
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
AutoBahned
search on strut + brace for literally thousands of posts on this
some are quite good at thought experiments/analysis and there is even a bit of real data out there also. |
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
I put an ERP strut bar in my 74S, and I may be wrong, but I can feel a tightness in the response now. its small, but there
You probably do feel something. How much you actually feel depends on a great number of things, for instance, I swear I can feel a bigger difference on an '89 or later than an early car.
The biggest difference I've ever felt a strut bar make was on my WRX it was almost night and day with and without the strut bar. I actually ran them front and rear on that car. Not much really improves Porsche suspensions and as such you tend to not see as dramatic of an effect, but it's there. It tightens things up a bit and prevents the suspension geometry from changing.
i put a strut bar on my 85 Carrera, had it corner balanced and 4 wheel aligned and what a big difference, feels like you have more control of the car when you are turning into corners.... you should go for it, you wont be sorry!!!
Black and Blue
+1 on the rennline strut brace - monoball package. Its a DIY install and it looks great. Plus, no drilling because the bottom cross member mounts under the brake booster thingy.
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Yes
The classic example: Replacing old, faulty spark plug wires with a new set of racy spark plug wires. Result: Instant power and torque, all because of: a) the brand name, racy, colorful spark plug wire set or b) a spark plug wire with good conductor/insulator Sherwood |
Unless the car is being tracked, is it really worth it??? That is what I got from his question. He said he's not racing, but not sure if that means no DE as well. I agree for a track car they are good stuff.
John Snodgrass 1973 Porsche 911 "Barney" (race car for sale) 2008 Nissan Maxima - Daily Driver 1999 F350 Diesel Crew Cab - Tow Beast 1990 Airstream 36' Land Yacht - Home Away From Home |
I'm with John. Can't imagine what these would do for you on the street. I'm pretty sure I'm not a good judge of these things, but I don't notice much on the track either.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
Air Medal or two
+1 for anyone who "drives " their car
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Not much on the 'nay' side of the ledger...
It's a cab (more body flex), he's driving on the street... maybe it's not going to give you that much bang for the buck. Anyone? |
Strut bars fall into that category of automotive accessories of "It can't hurt". The use of such products can't be easily tested for positive or negative impact in a street application and they generally look good and racy, as equipped in a dedicated track-based car; IOW, an aftermarket suppliers dream product.
Sherwood (I have one too) |
Why can't they be easily tested for a positive impact? It might not be terribly easy to do by yourself in your own car, but there's tons of data out there on them. The fact that certain mazdas and hondas come stock with them should mean something too.
I'm not sure you could argue a negative aside from the fact that it has to weight something.
AutoBahned
- benefits are tied to G-forces and to the SPECIFIC car they are used on - 'data' from a Mazda is of no value.
- on the street, G-forces are low - where are the "tons of data"??? I haven't seen ANY real data AT ALL. The best I have seen was a static load measurement posted here, but he used a piece of wood. And a claim in the old Automotion catalog that somebody had used a displacement or strain gage to measure tower movement - no data presented there. If you mean the plethora of "hey I put one on and it feels groovy" type posts, those are NOT data. They are are called anecdotes in the biz. - one could do a subjective evaluation on a known course, driven repeatedly at known speeds, BUT you would have to control for placebo effects, so that means several people involved to keep the driver from knowing when he has it connected. It is always possible that the magnitude of an effect is so large that no experimental design is needed. But that is not the case for a strut bar. It would apply to comparing something with truly great effects - like a flat tire. Last edited by RWebb; 07-12-2008 at 03:09 PM.. |
