OCD project capitan
Aluminum MFI linkage???
What are these aluminum mfi linkage rods and nuts off of? Are they from the Werks devision? One has a broken thread, the others are fine. They are 8.5grams lighter than the steel rods w/nuts.
![]() Aluminum ![]() Steel
Don Welch '73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper. |
Those are stock, the factory used aluminum because it better matches the expansion rate of the engine.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Tree-Hugging Member
Now, THAT is "attention to detail".
~~~~~ Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners. ~~~~~ |
IIRC, they were on the mag stacks used as the butterfly links. I think the plastic stacks of the '72-73 era used steel. At least there are steel ones out there that match the lengths of the butterfly linkages. When one gets all the rods out on a table, some are so slightly different that they could be placed in the wrong position and still work. All the rest are steel.
I belive my 72S had aloy and my 72T had steel but not sure.
Another item he caught (too bad he didn't see the rods) was the dick nose plunger on both the front and back latches. That is pot metal, not steel, and must be removed from the shaft and spring before plating. At the time, I wasn't sure it was a separate part. Thanks for remembering my little disaster, John, and thanks to the gentleman in NorCal (at the moment his name slips my mind) for loaning my some good AL rods while I searched for replacements. This is a great community. |
