How many quarts of oil for an '82SC?
Just finished converting my '76 Targa with a 3.0 from an '82SC. How many quarts of oil does it?
Old 07-15-2008, 05:02 PM
"O"man(are we in trouble)
widgeon13's Avatar
I'm sure others will confirm this but put in 8qts, run-up to operating temp and add oil until it comes below the top mark on the dip stick while the engine is running, should be another 3+ qts.
Old 07-15-2008, 05:45 PM
Eleven sounds right to me--I have an '83SC--and I wouldn't worry that "eight quarts" is way low, like putting one quart into a five-quart wet sump. It will be plenty to allow the engine to run up to operating temperature and then some. The reason 911 engines have all that oil--11, 12 quarts--is for cooling, not to keep bearings from starving.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 07-15-2008, 05:50 PM
RETIRED
Joe Bob's Avatar
I go ten....then fill after the engine is warm....
2012 ML350 3.0 Turbo Diesel
Old 07-15-2008, 06:29 PM
I thought the reason my 911 needed 11 quarts was because everytime I park she marks her territory
Old 07-15-2008, 06:32 PM
Don't know enough.
Does it have a front oil cooler?
Is it totally empty, including lines and RF fender cooler (if you have one)?
I'd put in 8, then add as needed per the dipstick, when HOT, IDLING and on LEVEL GROUND.
If it's totally empty, you will not put in as much next oil change as it will not all drain out.
Old 07-16-2008, 07:23 AM
LOL
That is funny.
Old 07-16-2008, 11:37 AM
