-   -   1971 911T Ignition timing & points specs?? (http://forums.pelicanparts.com/porsche-911-technical-forum/420269-1971-911t-ignition-timing-points-specs.html)
jayhackney 07-16-2008 12:46 PM
What are the numbers for :
(Bosche distributor)
Ignition points gap
Dwell
Ignition timing at idle
Ignition timing at 6,000 rpm
Many thanks.
Jay
1971 911T, 78 Targa SC, '84 911 Turbo
tswaney 07-16-2008 01:12 PM
Points gap: .3 mm
Dwell: 38 + or - 3 degrees
Timing (static): TDC
Timing at 6,000: 35 degrees BTDC
I think!
