Anyone sell Brad Penn in Orange County?
I did a search and the closest place I found was Oceanside. If I can't get it locally what is the recommended oil from Pepboys?
This is my weekend driver that gets an oil change every 3000 miles. Thank you
1955 VW oval window ragtop 1971 & 1974Triumph Bonneville 1985 Porsche Carrera 2013 Toyota Tacoma TRD 2016 Triumph Speed Triple R |
There is a guy in Long Beach but I can't remember his name. I was going to start carrying it but other business obligations got in the way. Maybe at some point in the future.
-Jess |
How about Royal Purple 20-50? Should be able to get it at pepboys.
I don't want to start using synthetic. It has never seen it and It will probably start leaking like a sieve.
I found several places from this site. Maybe you can do some search in there.
http://www.cal-look.com/forum/index.php?topic=20759.0
Fat butt 911, 1987 |
Also, you can send the brad penn folks a quick email or call them and they will refer you to the closest distributor to your home. You'll probably end up getting it sent to your home anyway tho. Good luck with your search.
