-   -   What determines the engine timing? (http://forums.pelicanparts.com/porsche-911-technical-forum/420622-what-determines-engine-timing.html)
Adelaide901 07-18-2008 08:18 AM
I have a 2.2 litre 911 T engine with e cams.
My questions are:
(1) What determines the timing value for an engine? Is it the cam profile? (wow - do I sound like a newbie?)
(2) What would the proper timing be for my engine?
Thanks in advance
911st 07-18-2008 08:36 AM
Look up the factory spec.
How much timing a motor will take depends on a lot of variables that together must be tested to see what is effective.
Compression, position & head profile, cam profile and timing, operating temperature... all effect ignition timing.
There is also a ignition timing curve as the effective timing changes with load and rpm.
On an older cars there are weights, springs and vacuum canister/s in/on the distribuitor that control the timing curve.
SP2 07-18-2008 08:36 AM
It is the cam profile. That is my guess. The timing recommendations for the same engine are different with different cams.
For example, my stock SC engine has a timing of (I think) 1.1mm for stock cams, but 1.26 for my 964 cams.
911st 07-18-2008 08:40 AM
More aggressive cams lower the effective compression ratio.
A lower compression ratio slows the burn rate and requires more advance.
Higher rpms require more advance.
If you have the original Pistons and compression I would start with the T specs and distribuitor. You could fine tune it on a dyno from there.
