Is this how you lower the 912 rear?
I have a 67 912 and I want to lower the rear from 26" to 25". I have done a ton of searches and they all point to adjusting the splines on the torsion bars.. Are the 912's different than the 911's in this case? Thanks for the help. I am about to put new tires on and I want to lower the car....
-Jim
75 911S targa SOLD
67 912 SOLD
1984 911 Carrera
Old 07-27-2008, 05:54 AM
forgot to add the photo...
-Jim
75 911S targa SOLD
67 912 SOLD
1984 911 Carrera
Old 07-27-2008, 05:55 AM
http://forums.pelicanparts.com/uploads8/clip_image0011158162493.jpg
This may help
___________________________________________
2001 Boxster S, Orient Red Current Vehicle,
1973.5 911 full factory "S" trim with a 3.2 engine **Sold**,2002 996 **Sold**,1975 911S **Sold**,
1971 911T **Sold**, 1968 912 **Sold**
Old 07-27-2008, 06:42 AM
jhora's Avatar
Jim...
You have to do it on the torsion bars....sorry no other easy way....adjustable spring plates give you just a hair that is good for corner balancing
Old 07-27-2008, 07:49 AM
356RS's Avatar
Jim, Just FYI. In the picture of your spring plate you posted, the hole on the left is for the camber adjustment, and the hole on the right is for toe adjustment.
Mark Jung
Bend, OR
MFI Werks.com
Old 07-27-2008, 08:03 AM
Originally Posted by John Hora View Post
Jim...
+1. Aside from the engine, the 912 is nearly identical to the 911 in all other components (slightly milder suspension due to weight differences.) Search and follow the threads here regarding reindexing the torsion bars.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 07-27-2008, 08:56 AM
I thought this was too simple.... Thank you for all the replies. Back to the search button!
-Jim
75 911S targa SOLD
67 912 SOLD
1984 911 Carrera
Old 07-27-2008, 10:13 AM
once you know the weight of the car, and you have the car jacked up (all 4 wheels) and level, measure the droop angle of the spring plate when it is completely free of trailing arm and the bottom 2 bolts of the spring plate bushing cover. Then you have a starting point to know what angle to shoot for as you reindex. If you are ordering stuff, I'd suggest new Neatrix spring plate bushings as a 'while you're in ther' deal. They are cheap and you don't want to have to go back later and replace them as it means a second corner balance and 4 wheel alignment.
You can pick up one of the angle finders at Home Depot for about 10 bucks. Use the calculator in this link to get you the new ride height.
http://vintagebus.com/cgi-bin/spring.cgi
edit: another good thread; long but good information.
Torsion Bar Problem, or maybe something else
Tony G
2000 Boxster S
Old 07-27-2008, 10:26 AM
