ischmitz's Avatar
Send a message via Skype™ to ischmitz
Smile Oil questions - please don't cane me
OK, here it goes. It's a three-part question:
1. What is a good or descent 0W-40 or 5W40 oil to get? I don't change it often and the car sits for periods of time so I might as well get something that has good long-term stability.
2. Are there any good deals going on in SoCal right now - I remember sometimes Target or Costco used to have some descent stuff by the gallon. Is anyone aware of something at the moment? I wouldn't mind spending a little less than 7$ per quart.
3. In absence of any deals what's the best place to shop for oil? Kragen's Autozone, other?
FYI, for the 964 engine I usually get Castrol GTX and I change the oil every 3k miles. The engine doesn't overheat so I don't see the benefits of a fully synthetic oil. The Castrol GTX is relatively cheap and seems to work. However, on the water pumper it's a different story. So let the comments begin.
Cheers,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 07-29-2008, 10:30 PM
1) Locate Brad Penn Dealer.
2) Pour green oil in car.
3) ??????
4) Profit.
1989 Carrera 3.2L in 993 bodywork
Old 07-29-2008, 10:33 PM
ischmitz's Avatar
I should clarify: I am looking for an oil to go into the wsater pumper. Unfortunately, Brad Penn oil is not even on the list of approved oils from Porsche and they don't make a 0W-40 or 5W-40 multigrade oil.
Old 07-29-2008, 10:42 PM
Ah yes, my mistake and then I just ignored the low cold-viscosity request.
I will add that some pretty smart people have noted faster viscosity breakdown rates with multi-grades that have a large cold/hot delta. I seem to recall the reading I did suggested, ideally, not more than a 30 weight difference. You mentioned it doesn't get driven much so this is probably a non issue for you.
Old 07-29-2008, 10:57 PM
synthetic sticks longer than dino.
It's easier to test in cold weather by wiping a metal sheet outdoors, but protected, with both favorites and coming back daily to wipe a finger across both.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-29-2008, 11:33 PM
Your 996 C4 must use a 0w-40 or 5w-40 for the VarioCam hydraulics. Anything heavier causes CE issues and misfires.
I'd be using Total Energy Quartz 9000. This is an excellent Porsche-approved 5w-40 available in 1 litre and 5 litre containers; under $6.50/litre, too.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-30-2008, 12:29 AM
