Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
LinkBack Thread Tools Rating: Thread Rating: 18 votes, 4.78 average.
Czar of C.R.A.P.
dfink's Avatar
Well the engine is apart and it looks really good. Something is not right with the mileage statement for the car. The car was purchased thinking it had 225,000 miles. The body is is excellent condition, and look at the engine in the pictures. I am going to make a guess that at some point the speedometer was replaced with an incorrect reading. Or at some point the engine was totally rebuilt. There was silicone sealer around the main case bolts but the cam tower to head seal looked stock. Anyhow here are some pictures of the inside. Does it look like 225,000 to you
92 C4 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 08-04-2008, 05:51 AM
If it was highway miles and properly maintained I would think the mileage is correct.
1980 SC
71 Chevelle SS454
Old 08-04-2008, 10:28 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Is something wrong with your autofocus? It is hard to tell what the condition is by looking at pictures.
If the engine was properly maintained you wouldn't really be able to tell mileage without measuring the pistons and cylinders. I have seen worse on "low-mileage" engines.....
'74 Targa 3.6 (not stock ) - '01 C4 (almost stock) - '00 ML430 (stock)
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2 - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 08-04-2008, 10:39 AM
Czar of C.R.A.P.
dfink's Avatar
I think I need a new friggin camera. This one just isn't doing the job. Better pictures soon.
92 C4 Coupe
Old 08-04-2008, 11:27 AM
Slumlord
Porsche_monkey's Avatar
Agreed. I was in the electronics store yesterday. Prices are shockingly low. Git 'er done...better pics required. This thread should be good.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 08-05-2008, 05:02 AM
Czar of C.R.A.P.
dfink's Avatar
have decided to have the cylinders bored. I have heard of US Chrome any others that can be recomended.
Will get some JE pistons. Still debateing the compression ration. Will likely do an engine management system so thinking of going 10.5:1 and using the engine managment system to keep it in check.
92 C4 Coupe
Old 08-05-2008, 05:20 AM
I really like the looks of the modified front & rear bumpers... who were they produced by? Thanks.
regards,
jlex.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 08-06-2008, 11:34 AM
Czar of C.R.A.P.
dfink's Avatar
Not sure who made the bumpers. It is a Ruf CTR "yellow bird" front and an IROC rear. If interested in a comparable set PM me. I have a set of CTR bumpers I purchased for my car that I will now not use.
Still not the best pictures but the engine parts were taken to the local John Deere dealer who ran them through a "hotsy" automatic parts washer. This would have taken hundreds of hours to get clean the way I did it last time. Basically a large dishwasher.
92 C4 Coupe
Old 08-07-2008, 10:25 AM
Czar of C.R.A.P.
dfink's Avatar
Well parts are off to machine shops so went to work on the fiberglass top. Many challenges to overcome on this one but I think we have made some progress. Was very difficult deciding how to attach the clamps for the front of the top. Finally designed a 1/4" alluminum bar curved to match the top then glued to the top with 3m panel bond. The latches were attached to the alluminum rail with some custom "homemade" aluminum brackets. Using different height shims the latching can be adjusted. Some pics
My God what have I done.........
92 C4 Coupe
Old 08-18-2008, 05:14 PM
Czar of C.R.A.P.
dfink's Avatar
Well some more advancement in the reconstruction of the top. The rear window ledge was pretty badly damaged. Wasn't sure how to fix it but finally came up with a method. I got some 3/4" plastic angle drywall corner protectors. I will use these to form a molding dam around the rear window. One side of the plastic angle will be bonded to theoutside surface of the window ledge. The other side will then act as a dam and be filled with panel bond to the desired thickness. This should give a very smooth straight surface for the window seal to set on. After the panel bond sets the backside will be sanded smooth. I sounds like a good plan pulling it off may be another story. I did get the plastic routed around the exterior. Will post more after the application of the panel bond
92 C4 Coupe
Old 08-21-2008, 06:04 PM
Slumlord
Now accepting donations for the CRAP New H.D. AutoFocus Camera fund....
84 Cab - sold!
Old 08-22-2008, 06:15 AM
charleskieffner's Avatar
herr finkster.................this is a classic example of..........." WITH BEER-ANYTHING CAN BE ACCOMPLISHED!" my hats off to you. cant wait to see it finished.
Old 08-22-2008, 06:25 AM
Czar of C.R.A.P.
dfink's Avatar
Well the first round with filler is done. It was a real PITA what I didn't anticipate was the glue makes everything slippery. The clamp positions that held before just made the plastic slide off. We finally got it though. To complicate matters the body shop loaning the gun for the panel bond said I would have 4 hours work time. No problem I can put everything on then come back and take the clamps off one at a time clean under them and everything will be fine. Whoooaaaa Nelly the stuff starts to kick in about 30 to 45 minutes. We took the clamps off in two hours. I think I heard him chuckling as I walked away to undergo this endeavor. But anyhow I think it will work out OK. Once it started to set pretty good I was able to take the clamps off and use a screw driver to scrape off any excess. This should save a ton of time sanding. I will have to add a second layer now that the clamps are gone to get everything even. We should have a very good surface now for the rear window to sit. Pictures after tomorrows secondary fill.
92 C4 Coupe
Old 08-22-2008, 06:30 PM
Czar of C.R.A.P.
dfink's Avatar
Also the engine plans are all set except for the cams. It will be a 3.2 to 3.4 conversion using JE 10.5:1 pistons. It will be fed by PMO ITBs with the TEC3r engine management system. Hope is to get somewhere between 300 and 340 at the crank with a final weight of 2300 lbs. Hopefully we will have to add weight to get to this.
92 C4 Coupe
Old 08-22-2008, 07:00 PM
Czar of C.R.A.P.
dfink's Avatar
The rebuild of the rear window lip continues.
One of the corners after the first pour.
Hard to see but the entire rear window area.
The auto focus gremlin appears again with the backside of the second pour
The edge after the first trimming of the edge
A little grinding of the remaining over pour and a block sanding of the edge and it shoud be good to go for a window. I plan to use generic locking window seal this will eliminate the need for the rear locking trim pieces and is a lot cheaper.
92 C4 Coupe
Old 08-23-2008, 06:50 PM
Czar of C.R.A.P.
dfink's Avatar
More pictures.
These are a piece of engine tin that the top tab where the spring clip goes had broken off. Used a piece of metal cut from the side of an old computer case. Overlaped about 1/2in. Then welded all the was around. I then cut the slot for the sring clip with the dremel.
92 C4 Coupe
Old 08-23-2008, 06:54 PM
gunlover05's Avatar
Hey dFink, great work!!
question, what autocross wheels and tire sizes will you put on this AX monster?
85 Carrera
2011 Cayenne Turbo
Old 08-24-2008, 04:15 AM
Czar of C.R.A.P.
dfink's Avatar
To start with would be 23X9X15 goodyear eagle slicks all the way around. See what happens. May have to cut out the fenders and go with something really fun. Right now money dictates used race tires.
92 C4 Coupe
Old 08-24-2008, 04:38 AM
Czar of C.R.A.P.
dfink's Avatar
Hey found some really great stuff working on the car today. A wire fried all the up the main instrumentation harness. Someone in the past had already tried to tape up the mess but didn't fix the root cause so it just kind off melted everything. Good thing all I really need is a tach.
I think it can all be saved pretty easy. Just some time and getting real friendly with the service manual. It's looking more and more like a switch panel will be called for to run the major items and the rest if just going to have to go. Weight is weight so out it goes.
92 C4 Coupe
Old 08-25-2008, 06:50 PM
the the is offline
Good job, that's a lot of work. Kurt was a really good guy, he tried, but getting the car really knocked into shape was a bit beyond him. It was lucky you found it!
Old 08-25-2008, 06:55 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
