Seat belt reel won't retract?
While installing my DAS rollbar I accidently triggered the inertia locks on the seatbelt reel. Any idea how to fix them so they retract once again?
Thanks, Dan |
the locks engage anytime the car is a few degrees out of level. (Or, if the belt spool is not in the intended orientation to gravity) The mechanism is simply a SS marble that sits in a bowl shaped perch. when the marble moves, it rides up the bowl and activates a lever with teeth that jams the belt spool.
If you have removed the spools from their mounting locations, you will either have to remount them, or mimic their orientation to the ground by slowly rotating them in your hand. Once correct orientation is achieved, if the belts will not retract, a few taps to unlock the marble should reset the lock. The front belts are mounted vertically. The rear ones are mounted in all sorts of locations. Good luck.
Matt 72 911T Targa - Sold Hang up the cell phone. Put down the Latte. Ignore the kids in the back seat. Use your blinker when you want to change lanes. AND DRIVE YOUR Fu@#!NG CAR!! |
Matt, thanks for the detailed explanation to the inner workings of this contraption. It was a hugh help!
![]() Dan |
