help identifying part?
:confused:Hi just pulled out my Right Cam shaft and this is what I found the P 202 tool does not worked it didn't fit.
the part #: 911-105-144 0R does any one knows what year cams are these? Thanks Eli It came out of a 77 S |
Seen this? mmmmm...Yum...Yum..on both counts!
<object width="464" height="392"><param name="movie" value="http://embed.break.com/MjUxMTQx"></param><embed src="http://embed.break.com/MjUxMTQx" type="application/x-shockwave-flash" width="464" height="392"></embed></object><br><font size=1><a href="http://view.break.com/251141">http://view.break.com/251141</a> - Watch more <a href="http://www.break.com/">free videos</a></font>
I'm not really sure what you're asking. You aren't very clear. Are you asking which camshaft you have? I believe that's what you are asking and so the answer appears to be 911S (1974-77). You're saying the cam socket doesn't fit so you need the cam bar P237, right?
nyne11... what does that have to do with his question?
HI Eli
the cam is the R/H one, from 1974-77 std 911 engine ; 911/93, 911/98, 911/42, 911/47, 911/43, 911/44, 911/48, 911/49, 911/81, 911/82, 911/84, 911/86, 911/89, 911/85. the cam may have been re-placed with a NEW one with the bolt type , or the old one has had the end snaped off and been repaired with a bolt?? regards mike |
| All times are GMT -8. The time now is 08:55 AM. |
