-   -   Anyone hear about a solution to failed brake light switches? (http://forums.pelicanparts.com/porsche-911-technical-forum/422337-anyone-hear-about-solution-failed-brake-light-switches.html)
Dennis Kalma 07-28-2008 06:03 PM
Hi guys, guess what, my brake lights failed again. 4th set in 5 years.
I heard that someone out there had figured out that the problem was too much current going through the things, causing some arcing which led to to the junction carboning up/failing. Solution apparently was some sort of relay....any one know anything about it or any other solution?
Dennis
slodave 07-28-2008 06:07 PM
Yes, numerous times. Search:
http://forums.pelicanparts.com/showthread.php?t=390422&highlight=brake+light+swit ch
Here is one thread.
rnln 07-28-2008 08:44 PM
here too. Yup a relay and some other components built into it. Installation is fairly simple.
http://forums.pelicanparts.com/porsche-911-technical-forum/419577-brake-fluid-weeping-brake-light-swtich-fix-sealant-teflon-tape.html?highlight=arc+suppressor
DRACO A5OG 07-28-2008 11:31 PM
Hey Dennis,
I be that someone. PM me and I will give the details.
Cheers,
Jim
