AutoBahned
RWebb's Avatar
Hard to Shift Transmission
I have a 1975 915 trans. that is very hard to shift.
It does NOT make a lot of noise (crunching/grunching/grinding/etc.) when shifting as I would expect if the synchros were bad.
What might cause this?
PS - shifter linkage is blueprinted a la Sherwood; newest model shift tower used with SC/RS (factory) SS and the coupler is carefully adjusted.
Old 07-26-2008, 10:56 AM
Randy,
Clutch fully disengaging?
Same symptoms in all gears?
Does it crunch gears going into reverse?
Upshifts and downshifts?
These questions are for the real gearbox experts, btw. Just trying to help.
Sherwood
Old 07-26-2008, 11:04 AM
Also interested to hear the answer, but, as I understand it, the short shifter on a 915 does make shifting more difficult.
Tony G
2000 Boxster S
Old 07-26-2008, 11:53 AM
AutoBahned
RWebb's Avatar
this is beyond what an old Target short shifter caused - that was likely a 20% reduction; whereas this one is only 10%
I think the clutch is fully disengaging - always hard to tell in a '75... there is no crunching re Reverse
problem seems ot be in all gears & both up or down - maybe less of an issue in the higher gears
Old 07-26-2008, 02:00 PM
I don't have that experience. Has to do with the gearbox internals and prior driving history.
Sherwood
Old 07-26-2008, 02:44 PM
83 CHECKER
i know this may seem to sound to good to be true, change your tranny fluid with swepco 201, the stuff has solved many a gear box issue, from hard shifting to synchro issues. $49.00 you can't go wrong, unless you know it is a linkage problem, then pass on the idea.
Old 07-26-2008, 03:08 PM
Virginia Rocks!
VaSteve's Avatar
How old is the clutch cable? Mine was ready to snap and what was left was stretching I suppose. It got very hard to shift into gear. I just finished changing it and test drove it this morning. Wow. What a difference.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 07-26-2008, 03:13 PM
flatsixnut's Avatar
I just replaced my cable and it made a night and day difference. Its a cheap and easy enough DIY to make it worth your while to check.
Michael
83 SC Coupe
Old 07-26-2008, 03:18 PM
Registered Cruiser
jorian's Avatar
"I just replaced my cable and it made a night and day difference."
I did this and the bushings on my 82' and it made a big difference as well.
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 07-26-2008, 03:30 PM
I have the same issue in 2nd and 3rd using the same setup you have. I think it is synchros though
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 07-26-2008, 04:56 PM
dtw dtw is offline
GAFB
How many miles on the trans, and how many of them have you put on (as what I am sure is a cautious and thoughtful shifter) versus the PO? Any rebuild history? Last fluid change? With what? Also, have you carefully examined the pedal cluster, especially at the clutch clevis? A disintegrated bushing there will cause major problems. Clutch cable age and condition?
Many questions .
Several BMWs
Old 07-26-2008, 05:08 PM
pwd72s's Avatar
I'm afraid I'm thinking the same. But..Randy? Call Gordon...really!
Old 07-26-2008, 06:02 PM
Immature Member
dentist90's Avatar
1. worn (internally, on synchro fitting surface) or missing dog teeth = put synchro ring oversize
2. worn/polished brake bands = reduce efficiency in bringing gear up/down to speed
These can make your tranny balkier. You don't get crunching, as when the synchro bands or slider are worn. Possible causes of reluctant shifting, anyway.
If you can shift into reverse without crunching after waiting about 3-4 seconds with the clutch in it's probably not clutch related.
edit: worn brake bands would lead to crunching, so disregard #2
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 07-27-2008, 01:40 PM
1984-911 M491
Trog's Avatar
When in doubt, take it to your trusted P-Car mechanic, and let him take it for a test ride.
1984-911 TLC......SOLD
Old 07-27-2008, 01:56 PM
Banned
I have a 75 with a 915. I was having all kinds of problems too.
Did the swepco, wevo, bushings. Turned out my clutch fork(?) was bending and finally snapped. Hope it's not that bad in your case, prepare for the worst.
It wasn't that expensive to replace.
Old 07-27-2008, 02:28 PM
AutoBahned
RWebb's Avatar
clutch cable is brand new; I always use Swepco. There is no trusted PCar mechanic anywhere near here. Portland is a 5 hour roundtrip and it is closest.
miles on the trans = unknown; I have you put on about 40 of them since R&Ring the trans; rebuild history = unknown
Paul - Gordon is definitely on my list (unfortunately, my house is falling apart nearly as fast as I can fix it up..., so I have not calle him as of yet). I would like to drive the car for just part of damn summer before rendering it inoperable again. Plan to take it in this fall.
Old 07-27-2008, 05:40 PM
dtw dtw is offline
GAFB
Your last hope(s) may be a check of the pedal cluster and one more linkage adjustment, but it sounds like it may be near time to open her up.
Several BMWs
Old 07-29-2008, 03:41 PM
tough shifting
I have found that this just appears to be the nature of these transmissions. You have to really pull and push into gear. No crunching, but it does seem to require manhandling, especially when compared to the old 901-911 transmissions. The newer cars are buttery smooth. It spoils you.
Old 07-29-2008, 04:32 PM
Not at all. The gearbox should go into gear like any other modern gearbox, albeit a little more slowly and methodically than most to not rush the synchros. Shouldn't have to force it if the internals are good.
Sherwood
Old 07-29-2008, 05:31 PM
AutoBahned
RWebb's Avatar
I'll add that this one seems much worse than I recall from shifting 2 other 915s in previously owned cars.
Most recently I had a typ 911 trans - I expect the 915 to be less light in feel than the 911.
I hope to drive the car a bit this summer and then let somebody else deal with this. Aftr R&R'ing various trans's about 20 times I've had it.
Old 07-29-2008, 09:28 PM
