rbuswell's Avatar
Porsche Crest Are fans on air cooled cars repairable?
I was cleaning the fan for my SC and a chunk fell off. When I inspected it more closely, I noticed a barely discernible ding right where the aluminum fell off and another ding on the top of the blade in front of it. I'm guessing that a stone snuck into the engine compartment and did the deed. Hard to tell how long ago it happened. Here are some pictures:
Am I SOL or can someone who welds and works with aluminum fix this? A friend told me that guys who weld aluminum propellers for boats can do wonders with this kind of stuff. Of course, I'd be worried about balance. Can it be run as it is if it can't be fixed? Thanks for your input.
1982 911SC
1987 924S
Old 08-01-2008, 03:43 PM
Slumlord
Porsche_monkey's Avatar
I would smooth it off with a file and drive it. Just make sure there are no crack propagating from the damaged area and inspect it the next few weeks. If a crack develops drill a small hole to prevent it from spreading.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 08-01-2008, 03:52 PM
Hard to tell exactly how big that "ding" is, although I can guess. What we usta do with airplane propellers when something like that happened was grind the jagged break to a smoothly radiused loss-of-metal without stress risers. And if you were a bush pilot and had really taken a whack out of one blade, you cut off the equivalent amount from the opposite blade and restored balance.
I have a fairly large ding on my fan--though not quite as deep as that--that I smoothly radiused and let it go at that. I don't think balance is a huge problem at the speeds the fan is turning--it's not a turbine, after all--but you do want to get rid of the stress risers, which are jagged, sharp-edged corners from which cracks propagate.
Whether it can be welded, I dunno. It's not aluminum--which would be easy--it's a magnesium alloy, I believe. Magnesium burns.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 08-01-2008, 03:55 PM
abit off center
cgarr's Avatar
Just for fun I would try to build it up with some Alum epoxy, shape it in and run it, see how good the stuff really is, otherwise I would just clean up the sharpies and run it.
______________________
Craig
G2Performance
Old 08-01-2008, 04:52 PM
rbuswell's Avatar
Porsche Crest Answers to questions
Boy, it really seems like aluminum although it may be an alloy. The ding on the top of the adjacent blade is small and flat and doesn't appear to have any radiating cracks so I hope that never amounts to a problem. Neither does the actual broken section have any obvious radiating cracks. I like the idea of rounding it out and running it. It's also good to know that balance won't be too big a problem. I've seen a new fan on evilBay for about $240 shipped but I obviously don't want to spend that if I can avoid it.
As for an aluminum epoxy product, is there a brand and source that you recommend?
1982 911SC
1987 924S
Old 08-02-2008, 08:23 AM
abit off center
cgarr's Avatar
I have used the Devcon Liquid Alum before, its a 2 part system.
Craig
G2Performance
Old 08-02-2008, 08:32 AM
Sultan of Sawzall
rouxroux's Avatar
Sounds like a drummer trying to save a favorite cymbal. BTDT.
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Jet engine compressor blades are repaired the same way. I'd skip on the epoxy though. It's either going to be ugly and not much more effective than the ding in the blade or snap off. Blend the blade and keep an eye on it for cracks.
'84 911, some sort of red color
'05 Subaru WRX wagon
Old 08-02-2008, 09:09 AM
Trust me, it's not aluminum.
Stephan Wilkinson
Old 08-02-2008, 09:29 AM
rbuswell's Avatar
Porsche Crest Thanks, Steve
I'll take your word on that. By the way, I finally got around to reading your book and I couldn't put it down. Thanks for writing down what I'm feeling right now.
1982 911SC
1987 924S
Old 08-02-2008, 12:27 PM
Hey, thank you for saying that! 'Preciate it.
Stephan Wilkinson
Old 08-02-2008, 02:29 PM
scarceller's Avatar
The fan is magnesium.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 08-02-2008, 05:20 PM
scarceller's Avatar
Here is an aluminum one:
http://**********.com/ShowItem/208322%20Porsche%20911%20-%2011%20Blade%20Alternator%20Fan%20-%20Aluminum.aspx
Sal
1964 356SC (SOLD)
Old 08-02-2008, 05:50 PM
