I was cleaning the fan for my SC and a chunk fell off. When I inspected it more closely, I noticed a barely discernible ding right where the aluminum fell off and another ding on the top of the blade in front of it. I'm guessing that a stone snuck into the engine compartment and did the deed. Hard to tell how long ago it happened. Here are some pictures:
![]() ![]() Am I SOL or can someone who welds and works with aluminum fix this? A friend told me that guys who weld aluminum propellers for boats can do wonders with this kind of stuff. Of course, I'd be worried about balance. Can it be run as it is if it can't be fixed? Thanks for your input.
1982 911SC 1987 924S |
Slumlord
I would smooth it off with a file and drive it. Just make sure there are no crack propagating from the damaged area and inspect it the next few weeks. If a crack develops drill a small hole to prevent it from spreading.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Hard to tell exactly how big that "ding" is, although I can guess. What we usta do with airplane propellers when something like that happened was grind the jagged break to a smoothly radiused loss-of-metal without stress risers. And if you were a bush pilot and had really taken a whack out of one blade, you cut off the equivalent amount from the opposite blade and restored balance.
I have a fairly large ding on my fan--though not quite as deep as that--that I smoothly radiused and let it go at that. I don't think balance is a huge problem at the speeds the fan is turning--it's not a turbine, after all--but you do want to get rid of the stress risers, which are jagged, sharp-edged corners from which cracks propagate. Whether it can be welded, I dunno. It's not aluminum--which would be easy--it's a magnesium alloy, I believe. Magnesium burns.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
abit off center
Just for fun I would try to build it up with some Alum epoxy, shape it in and run it, see how good the stuff really is, otherwise I would just clean up the sharpies and run it.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
As for an aluminum epoxy product, is there a brand and source that you recommend?
abit off center
I have used the Devcon Liquid Alum before, its a 2 part system.
Sultan of Sawzall
Sounds like a drummer trying to save a favorite cymbal. BTDT.
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) |
'84 911, some sort of red color '05 Subaru WRX wagon |
Trust me, it's not aluminum.
I'll take your word on that. By the way, I finally got around to reading your book and I couldn't put it down. Thanks for writing down what I'm feeling right now.
Hey, thank you for saying that! 'Preciate it.
The fan is magnesium.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Here is an aluminum one:
http://**********.com/ShowItem/208322%20Porsche%20911%20-%2011%20Blade%20Alternator%20Fan%20-%20Aluminum.aspx
