1984-911 M491
Transmission rebuid - Car coming home
I'm pleased to report that my 915 tranny rebuild is complete. Through the efficiency of our host, and a few other part suppliers, we managed to get all the bits and pieces we needed and had the project finished within 8 working days. Not bad, not bad at all. I pick-up the 911 tomorrow afternoon at which time I'll report on its performance. However, my mech states it's the best tranny rebuild he's done to date.. and he's done plenty. I hope I'm not disappointed. BTW parts alone set me back $6000.. ouch!
Here's a few of the goodies installed: ![]() ![]()
1984-911 TLC......SOLD |
1984-911 M491
And here's the bits that came out. Criteria, any irregular wear, replace the part with the hope that with proper treatment, the tranny will last 100,000 miles before the next rebuild.
1984-911 M491
Performance report.
With great anticipation, I picked up the car Friday afternoon. The first thing I noticed was the feel of the WEVO gateshift. I needed to reprogram my shifting habit to match the gates. Once that’s mastered (all of 5-minutes) the gateshift is pretty transparent. The 2-3 shifts does force you through neutral, as expected. No more shifting in the diagonal. Apparently, the PO’s mechanic had done some work on the tranny. Seems he installed the 1st & 2nd gear sleeve backwards making 1-2 shifts rather difficult. Matter of fact, it was nearly impossible to get it into 1st, and 2nd was hit and miss. Now with the rebuild, it shifts into 1st real easy. 2nd gear still takes some effort if I don’t give the synchro a second. As long as I don’t rush it, it snicks into gear. I have yet to try a 1-2 power shift (rather not). 2-3, 3-4, 4-5, 5-4, 4-3, 3-2 and 2-1 shifts are a breeze.
Was it worth the $9 large.. probably not. But what the heck. It’s not like I need both kidneys, right? Breakdown: $6500Parts Labour: $2500
1984-911 TLC......SOLD Last edited by Trog; 07-28-2008 at 10:04 AM.. |
This a 915 gearbox? Despite all the goodies and extras, do not power-shift...that's what M-22 Muncies were designed to do. NOT 915's. You do realize the history here, yes? The 915 is a derivative of the 908 race car transmission design. Drag racing type speed shifting was not part of the design...
WEVO makes good stuff...but shifting gates etc. don't change the design of what's inside. Take your time, do it carefully when selecting gears with a 915.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
1984-911 M491
Hopefully one of the experts will chime in here, but that seems extraordinarily high, even with the "goodies."
1984 Targa |
1984-911 M491
Well, I did take care of a few other issues while the car was in the shop. The labor for the tranny work was about $1700, with the remainder going towards suspension and chasing oil leaks.
If you're gonna do it, do it right. My car had some sort of transmission overhaul in the last 25K miles and it doesn't shift that well, probably because it was done cheaply.
'84 911, some sort of red color '05 Subaru WRX wagon |
gearhead
The average price of a 915 gearbox coming through my shop is probably around $3500-4500 for a street box. When you do a full remanufacture on it, it's usually more around $6000-7000. Race builds with LSD's, bearing plates, and special ratio gears are usually $9000-13,000 depending on what exactly we install.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
1984-911 M491
I have one word of advice for anyone contemplating a tranny rebuild. Do your homework. Based on everything I read, I anticipated that at most, the cost would have been $5-6 thou.. and that’s with parts. But until you get the gear-box opened up, you have no idea what you’ll find. Plus, there’s a real desire to change marginal parts, just ‘cause you’re already in there. In addition, through no fault of their own, I sense that most mechanics low-ball the cost of repair in fear of losing a potential customer.
If you want to avoid surprises, prepare an estimate including any optional equipment you may wish to install, then double it!
gearhead
1984-911 M491
In 1984, the sticker price for my car was $45,000++. In 1984, I could purchase a nice Mustang GT with 5-speed for about $12,000. The Mustang tranny was bullet-proof. The Porsche, not so much.
So, who in their right mind would accept a car, costing almost as much as a house, with the 915 transmission? If this is how they worked when they were new, then I would have had my lawyers contacting Porsche to demand restitution? Were all the supercars of that era plagued with marginal gear-boxes?
gearhead
But you also need to look at what was going on in our society at that point. In the mid-80's a Porsche 911 was a status symbol that was only rivalled by the Ferrari 328 and the Lamborghini Countach. It was far far less expensive than those true exotics. Those same Ferraris and Lamborghinis needed a major service and a valve adjustment every 5-6k mi. And those services cost thousands of dollars. A 911sc or a 3.2L Carrera on the other hand was a jump in and go vehicle with service intervals similar to what you see on a Camry or an Accord. It was the best of both worlds giving you a sports car that was close in performance to the Italian cars but with cost of ownership more on line with the other German marques. On top of it all, it had the racing heritage that so many of us embrace today. We could look back at the 911's and 935's of the 60's and 70's and there was a direct lineage leading to the street cars of the 80's. In return for that, many people were willing to accept a transmission that was outdated, funky, and decidedly Porsche.
1984-911 M491
Matt, I guess you summed it up perfectly.
If the 911 was able to run with the Ferrari’s and Lambo’s for a fraction of the cost, then that would indeed award it a certain amount of ‘character’. Considering its Achilles heel, I guess one had bragging rights if they knew how to drive a 915-equipped vehicle. In a time when cars were increasingly lacking character, I guess it meant something owning a vehicle that valets were unable to park. I’ve driven both 915’s and G50 911’s. And for my money, I prefer the 915. There’s something about ‘working’ the tranny that makes driving the car so engaging. The double-clutching, the rev-matching, the sounds and feedback, seem so period-correct. If I need a perfect gear-box, I can always take my Mazda for a spin.
RS 73
I did a similar rebuild on my 915 about 18 months ago. I paid in line what you did.
I also put in a billet side cover replacing the stock one for more strength. I really like what the Wevo shift gate did for the shifting, but I quickly found out my linkage needed some help. I had a Weltmeister quick shift kit in the car at the time and it was a mess. This shifter raises the pivot point both laterally and fore and aft. The Wevo does not like this. I put in the factory shift kit and this made a huge difference. The factory kit has all new internal parts for the shifter so this tightens everything up, and the lateral shift ration stays the same so it matches the Wevo gate. I also changed the coupling connecting the shifter rod to the trans to the Wevo. $200 for this part is steep, but it is beautiful and works well. You can put new plastic bushings for $20.00 in parts, but it too will get sloppy in a couple of years. If you are not sure about your shifter and linkage I would at least replace all the plastic bushings. I like the shorter shifter, but that is not everyone's taste. One minor note on the shifter, the shaft is brazed into the lower area. A month after the install this let go and I had to take it all back out and re-weld it. So I am an expert at assembling this shifter. Dick |
1984-911 M491
One of the first upgrades I did was installing a WEVO shifter, change bushings and installed a Strompsky shift coupling.
So, that's it for gear-box/shifting upgrades. Now I get to focus on suspension, but that will have to wait till next year. I'm thinking coil-overs.
RS 73
Good for you....you are way ahead of me in the shift control area. Good work.
I just could not believe how badly my new transmission shifted because the shifter and coupling were so sloppy!! |
what? $9k to rebuild a tranny? Am I missing something here... or it's simply the price for driving a 911?
Fat butt 911, 1987 |
1984-911 M491
Like most things in life, you get what you pay for.
Trog:
Can I ask who did the work, and how happy you were with them?
_____________________ These are my principles. If you don't like them, I have others.—Groucho Marx |
