Anyone rewired their car with an aftermarket system?
While in the process of converting my car to a mainly track machine I have completely removed the harness. As expected being 40 years old the wires are brittle, there are cracks and many of the connections have obviously been repaired over the years. I have thought of obtaining the correct coloured wire and building a new harness but then the thought struck that there are plenty of companys out there who make 'generic' harnesses with modern fuse panels and all the circuits I would need for a car with power nothing
![]() For example these guys http://www.ezwiring.com/wiring_harness.html So anyone rewire their car using one of these systems, how did it go and any gotchas I should watch for? Also any recommendations of a good source?
Robert Currently Porsche less (but the wife has 2) |
I used the VW kit from watson streetwerks. They have a made for them harness from american autowire. Should be everything you need. The only thing I noticed missing was the backup light circuit.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
I have done my '74 track car using a Painless street/strip kit. I was in the same situation as you were, my harness was removed and mangled by the PO. I decided to redo it an save some weight and gain reliability at the same time. Used an 8 switch box with modern fuses.
I would recommend becoming very familiar with the color coding of our 911s. I wired and routed one system at the time. I ended up splicing the kit to my OEM harness by the starter, soldering and shrink wrapping. Did this because I wanted the plugability of the 14 pin connector and also because the kit was made for front engine cars and I did not want to extend individual wires more than necessary. I think it was well worth the effort, but it is not for the faint of heart since it can be a very complex project if you are not familiar with how the systems function. Including pictures... Enjoy! Lou ![]() ![]() ![]() ![]() ![]() ![]() ![]()
'76 911 "Moneypenny" daily driver '74 911 "JLo" IROC DE Car '03 CRV, '02 Jeep Grand Cherokee '03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft# http://www.nicotra4.hpshare.net/BasketCaseMotorsports/ |
Here are some links from my research:
http://www.painlessperformance.com/ http://www.isqe.com/ http://www.watsons-streetworks.com/ http://www.ynzyesterdaysparts.com/ http://www.centechwire.com/index.html http://www.americanautowire.com/ Jim S.
I say we take off, and nuke the site from orbit. It's the only way to be sure. 2009 Cayman |
Thanks for the links. I have a 68 so it's wiring is pretty simple already, the only issue I can see is that it has a alternator with an external regulator so I have to figure that out.
The Puff.
How about a harness for an '84 with power windows, a dome light, and a trunk light? My wiring has been completely messed up by the PO.
Thanks, John
'70 CT1B '11 GTS 300 Super |
I have wired 3 cars (60's mustangs and a FFR Cobra sorry) with the EZ wiring kit. If you are looking at painless be sure to check out EZ wiring. They are on Ebay and sell for $165. The painless is quite a bit more and really not that much different. I have used both.
-Jim 75 911S targa SOLD 67 912 SOLD 1984 911 Carrera |
The Puff.
What would I do about the circular relays?
The Puff.
I guess I would also have a rear defroster to worry about. Would I just have to splice in the old stuff?
i used the painless universal 18 circuit harness. it is fine except the documentation is not great. the wires are all labeled but it is really for a muscle car, not a porsche. the most difficult part is spicing into the turn signal and wiper stalks, the porsche wiring is quite different than the painless system. if (and when) i need to do this again i would just do it from scratch.
BMW 128i 73 rsr clone - sold 68 912 project to become 911r (almost done!) |
those of you that used EZ, which kit? The link in the first post shows 3 separate kits.
Thanks.
James 1969 911E Slate Grey 1981 911SC Wine Red 1997 911C4S Ocean Blue |
The Puff.
I just purchased the mini 21 kit... I'll tell you how it goes.
--John
Sorry, I can't speak about the circular relays. I know the kit comes with relays for the horns and an electric fan. It's a very nice kit for the money. Good luck!
