subaru engine into 911!!!
May seem like sacrilege but could you fit a flat 4 Subaru Impreza engine to a '73 911? Would you be able to use the 6 speed Subaru gearbox? I hope this could work as the engine would probably be slightly lighter weight, more reliable, easier tuned and much cheaper than a 911 engine. Also the shorter length of the engine should mean better weight distribution. Opinions.
Old 08-04-2008, 02:38 PM
I have not read this thread in a while, but it may be helpful:
putting a 3.3 in my SC
1979 911 SC Silver
2002 996 race car
2005 Ford Excursion
Old 08-04-2008, 02:40 PM
300hp 1800lbs is the goal
pksystems's Avatar
Subaru tranny would have 6 reverse gears, and 1 forward, and from what I've heard you can't flip the diff or whatever. Get a tranny adapter from Kennedy engineering to mate the subaru motor to porsche tranny. Then you need radiator/hoses..etc....etc...
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 08-04-2008, 02:44 PM
jabb's Avatar
Here is a 914 Suby conversion ..... hope this helps.... It takes lots of time and fabrication skills.
http://www.etischer.com/914xt.html
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Given enough time and money almost anything is possible. However, I have a feeling that getting the Subaru transmission to work would be extremely difficult (facing the wrong way + coming out of an AWD car). Another challenge, albeit a workable one, will be locating the radiators.
Old 08-04-2008, 02:46 PM
abit off center
cgarr's Avatar
Years back in the 912 section here a guy did this and it turned out very well. Also running them in a lot of aircraft now.
the porscharu has begun
______________________
Craig
G2Performance
Old 08-04-2008, 02:48 PM
Tags
distribution , impreza , subaru , swap
