wannabee wannabee
SSI's & Bursch on an 84?
Can I mate my existing Bursch exhaust (w/ cat bypass) to a pair of SSI's? I particularly like the Bursch scavenging sound.
99 C4 - (let's try this once more) 07 Cayman S - sold 11/17 (not the same) 84 Carrera - sold 3/16 (geez what have I done!) |
The stock Carrera exhaust your using the bypass on is a one inlet into the muffler setup. The SSIs backdate your exhaust into a two inlet. I suppose it maybe possible to have your muffler modified for a second inlet.
1987 911 Carrera 2006 Audi A3 |
The short answer is you need a 2 in muffler. On top of that, the Carrera's (and SC's I think) will need to have oil lines that back date the oil system. If you look at the SSI's in the Pelican Parts site, you will see they show the 2 lines you need. The existing Carrera oil lines interfere with the right side headers (including the backdate SSI system).
Tony G 2000 Boxster S |
wannabee wannabee
Thanks so far!
Does it make sense to use pre-74 SSI's then? I think I read somewhere that adds HP. Also Fabspeed muffler sounds deep & throaty or am I mistaken. Any other cheaper muffler suggestions? Man this is getting expensive...
The SSI's are pretty much exactly the same as the 74 and earlier exhaust except that they are stainless steel. I would suggest you check out the M&K mufflers available through Pelican.
