fuel pump relay...where?
I have a 1991 Carrera C4 which is randomly suddenly ceasing to run. I thought perhaps it is a fuel pump or fuel pump relay problem. I thought the relay would be the simple thing to do first. I have the relay from Pelican but now I do not know where it should go? I found relays in the engine compartment and in the trunk but none match.
I don't have a 964.... but I do have the wiring diagram. You do have a DME relay. Powers fuse 34 wherever that is.
Maybe someone will chime in where it is. My 88 it is under the seat.
Rick 88 Cab |
