930 Heater flapper box help???
I have a 1985 930 and as I have the engine out I am sorting out the heating.
I have attached two photos of the flapper boxes and I need to know if they are the correct type for a 930? Do the flexible orange heater hoses connect direct to the flapper boxes as I have shown in the photos or is there some other parts? Any help or advice would be gratefully received... Steven Carr Left hand Flapper box http://forums.pelicanparts.com/uploa...1218407092.jpg Right Hand Side Flapper box http://forums.pelicanparts.com/uploa...1218407124.jpg |
My orange SCAT tubing just connects to that part, just like you have. I would lube those springs and other parts real well while you have them available.
The left hand box may be a later (87-on) replacement part but it should work. If you have automatic heat, the elbow part needs to have a provision for the sensor that tells the controller the temperature of the air passing through the valve.
JR |
It appears that you have flappers from two years, which one is for what year I don't know.
The left one should have a small tube welded on it that the control cable housing goes into. The right one has that tube on the hose clamp. Either work just the orange tube is a different length. |
Thanks for the help it is appreciated.
The left hand box has a hole in it for the auto heat sensor. Have a look at the Porsche drawing it shows the item I have circled in red. I don't have this on my 930. Should I? Regards Steve http://forums.pelicanparts.com/uploa...1218469725.jpg |
That's what was on there originally. Yours looks like it has been replaced and the later ones look like the one that is now on your car.
JR |
