Dyeing Paper Duct Hose
I'm in the home stretch of buttoning up my cabriolet's 3.0 engine. As part of that, I've been routing the heater duct hoses, which led to a challenge. The ham-handed previous owner had made a mess of the long paper-covered hose that goes from under the A/C bracket and then up and around the fan housing to the Y-connector at the heater blower. Too bad, because otherwise the hose was in brand-new condition, with a nice satin black finish to it.
In a box of spares I had a good replacement hose with the exception that it looked tired as hell -- kind of dirty and faded to a cruddy shade of brown. I've had success using RIT dye to re-dye my heater knobs and I had bought a package of black dye to re-dye my accelerator pedal (OK, yes, I'm sick). This got me thinking ...
I mixed a small batch of black dye in a cup of hot water. Using a sponge, I applied the dye to the hose. The paper absorbed the dye and the hose section looks terrific now.
By the way, I tested the dye mix on the larger diameter hose and it doesn't work well at all because the outer covering is different from the smaller-diameter long hose. For those sections, I dusted them lightly with some flat black paint.
The bottom line: There might still be some life in your fading paper-covered duct hose.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 08-12-2008, 06:54 AM
Danny_Ocean's Avatar
Would the spray-on (aerosol) vinyl dye for interiors work?
Old 08-12-2008, 06:58 AM
Possibly, but RIT dye is cheap, something like $1.49. If you already have the vinyl spray you could test it on a small section.
The neat thing about dyeing the hose is that there's no paint buildup on the part.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 08-12-2008, 07:03 AM
19 years and 17k posts...
azasadny's Avatar
I replaced all my my hoses with SCAT hose from Aircraft Spruce. It's not cheap, but it looks great and is very durable...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 08-12-2008, 07:10 AM
That's a great option if you can live with a non-original look. I'm a bone-stock owner with a cheap budget.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 08-12-2008, 07:11 AM
KCPSG's Avatar
I have about 6' (maybe more) of the SCAT hose, that I will not use... PM me if interested
Phil
2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift
1988 911 coupe (GP white) Turbocharged
1998 BMW 328i
Old 08-12-2008, 07:22 AM
Wandered off somewhere...
Drdogface's Avatar
I tried the Scat stuff and didn't like it. Finally went to this from McMaster/Carr. Hard to work with but I like the effect...
Mark...
Porsche Boxster S
2012 Jeep Wrangler Rubicon..Crush Orange
Old 08-12-2008, 07:28 AM
azasadny's Avatar
Mark,
That looks great!
Art Zasadny
www.ford.com
Old 08-12-2008, 08:11 AM
Drdogface's Avatar
Art,
Thanks... It's Stainless Steel flex hose and will cut you to ribbons if you're not careful. I had to make some partial cuts to help with the bends. It's a bit different now from the pic above in that I was able to bend it down a bit more on the right and clamp in place... Shows up really nicely thru that diamond mesh grill material we bought from Norway...
Mark...
Porsche Boxster S
Old 08-12-2008, 08:28 AM
